thinner head gaskets?
Old Apr 14, 2011 | 07:14 PM
headed-ws6's Avatar
Default thinner head gaskets?
Hi everyone i am about to install some 799 heads and an asa cam, but have been thinking about up using a thinner gasket to up the compression a little more. How thin could I go safely? Thanks for any and all advice.
cam specs
226/236
.525/.525
110 lsa
Old Apr 14, 2011 | 08:08 PM
trans_am7935's Avatar
i just installed PRC heads with 62cc chambers and used a .040 head gasket, the cam i installed was an LSR cam speced to 227/235 .617/.621 113 LSA, you should be fine, but i would check just to be sure. check out my build thread, it might help you a bit.
Old Apr 14, 2011 | 08:50 PM
headed-ws6's Avatar
Yeah my 799 heads are stock and i think 63-64cc heads if it is possible id love to run a .040 gasket to up that compression
Old Apr 14, 2011 | 09:20 PM
with my 62cc heads and .040 head gasket, i am running 11.1-11.2:1 compression
Old Apr 14, 2011 | 11:19 PM
headed-ws6's Avatar
I should be okay I think that would put me at a 10.7 or 10.8 which would be nice just dont want to have to fly cut or worry about ptv
Old Apr 14, 2011 | 11:38 PM
'02 WS6's Avatar
TSP Stg 2 LS6/799s w/ 59cc chambers, .057 MLS gasket, and 237/235 is what I ran so I think you should be in the clear with 64cc and .040 gaskets. Had it dead on @ 11:1-11.1:1
Old Apr 15, 2011 | 01:24 AM
headed-ws6's Avatar
sweet im tryng to get as much as i can on a budget.
Old Apr 15, 2011 | 03:10 AM
itsslow98's Avatar
if the heads are gonna be off, you might as well measure to be sure.
Old Apr 15, 2011 | 10:25 AM
headed-ws6's Avatar
Is there a write up on how to measure PTV? Id like to measure as stated and be safe then sorry.
