Is 400rwhp and 400rwtq possible w/ stock heads?
Old 06-03-2011, 10:09 AM
Detoxx03's Avatar
It can be done and you don't need a ridiculously big cam to do it either
Old 06-03-2011, 01:18 PM
180ls1's Avatar
agreed, if you did you would just kill your torque.
Old 06-03-2011, 01:23 PM
jc98ss's Avatar
i made 401 but my torque was low, kinda disappointed on that....cam in sig, full bolt ons, 36lbs injectors, ls6 int, UD pulley, lightweight clutch, stock gears.....357rwtq isn't much more than stock, WTF??
Old 06-03-2011, 01:28 PM
Rise of the Phoenix's Avatar
Originally Posted by '02TA
'02 Trans am with Hooker LT's, TD's, stalled auto, 4.10's, UD pulley, K&N & TB, 230/230 .612/.604 110+4 LSA. Made 390 rwhp and 380 tq on a mustang dyno. Through a 6 speed I think it would have hit your goals.
EDIT: I don't think it makes a difference but my T/A was one of the f-bodies that got a LS6 block
Mine did too
Old 06-03-2011, 01:31 PM
Yeah, I agree. I don't want to loose the torque just to make horsepower. I want a good balance. I'm debating on a 227/233 110 LSA or a 230/230 110.
Old 06-03-2011, 03:18 PM
Detoxx03's Avatar
I did it with a F11 from Futral Motorsports and that's a 228/230
Old 06-03-2011, 03:23 PM
MrDude_1's Avatar
I did it with a 224/228 on 114 through a 6spd... but I had different headers then you (it was in a 3rdgen Fbody)
I also found out on the dyno that my parking brake sinks 40hp.
Old 06-03-2011, 03:32 PM
That torque is low. Who specked out the cam for you and who ground it? What lobes? Also, who did your tune?
Old 06-03-2011, 03:44 PM
lemons12's Avatar
With a big cam your aren't going to lose tq it just won't have the feeling under the curve that a smaller cam has.
It makes an illusion that you lost power down low, or tq.. just like headers.
Old 06-03-2011, 10:55 PM
DONAIMIAN's Avatar
Did it 7 years ago with 221/221 112
Old 06-04-2011, 02:08 AM
jc98ss's Avatar
Predator-Z spec'd it, it's a Comp Cam on LSL lobes....i guess Comp ground it, i bought it from a non vendor (HK Racing engines).....i have a ton of confidence in the setup, but i think i got ripped on the tune and it could be alot better.....it was tuned by Jerry onks at Vettesport in Smyrna, TN, there a some driveability issues that i've just learned to live with since the tune, i'd rather not take it back to him.....he's a great guy and we didn't have any disagreements, i just sort of question his knowledge on tuning compared to how my car ran with the Frost tune......now it searches for idle for about ten seconds after i start it up, there's some surge at low speeds, when i run A/C it won't idle until the motor is fully warmed up, the idle rpm is about 125 rpm higher than i would like it to be set (i wanted 110lsa for a reason, it sounds more like a 113-114lsa) and the exhaust smell is really strong when i'm sitting at a stoplight.....
other than that, i also need to go back in and change my valve seals, i think i might have crushed one or two of them with the Tim's tool when i was installing the springs because it spits out a little white smoke at idle and i'm consuming about a quart of oil every week.....i didn't smoke or use a drop of oil in between 3000 mile changes when i was just bolt-ons with a Frost tune.
Would extra oil seeping down through the valves kill my torque?
Old 06-05-2011, 10:11 PM
  #32
ms4z28's Avatar
I put down 439 with stock heads and an ls6 with a tsp 233/239 cam. So yes..
Old 06-05-2011, 10:55 PM
  #33
LSX Mechanic
Damian's Avatar
Do not waste your time with an El Turdo....I mean El Torro cam. It makes a decent TQ curve, but I've never driven a car that felt fast with one and they don't really make much power above 6K. The TQ is linear, but it's not violent.
The 227/233 on LSL lobes would be a good choice.
As for your original question. 400/400 was made on stock LS heads right around the time Bill Clinton was getting blow jobs in the white house. That's old news sir.
Old 06-06-2011, 02:25 AM
  #34
PREDATOR-Z's Avatar
Yeah, right
http://i297.photobucket.com/albums/m...0cam20dyno.jpg
Old 06-06-2011, 03:20 AM
  #35
TORCHD 02 TA's Avatar
What cam to acheive this?
2002 WS6
6 speed
long tubes
true duals
ls6 intake
SLP air lid
Would a 228/232 110 LSA or a 227/233 111 LSA get me there? Also, what about the "El Torro" cam. Anyone have any numbers with it?
I run a 228/232 on a 110+4 cam.. See my mods in sig.. I make at the rear 419/382.. Dynoed on Straightlines Mustang dyno too
Old 06-06-2011, 04:14 AM
  #36
same o'j's Avatar
Default G5x3
2002 WS6
6 speed
long tubes
true duals
ls6 intake
SLP air lid
Yes absolutely it is possible. i made 416rwhp 400rwtq with G5X3 cam and stock 241 heads
Old 06-06-2011, 05:36 AM
  #37
Felix C's Avatar
Fellow here many years ago made 400/400 with a 224/224 563/563 110/106 open exhaust though. Stock 241s+LTs+UDP.
HP peaked at 6000rpm.
Old 06-06-2011, 12:54 PM
  #38
What's the benefit of the LSL lobes? Was thinking about having Cam Motion grind the cam. Or possibly EPS. Also, what would you recommend for ground in advance?
Old 06-06-2011, 09:50 PM
  #39
1999FirehawkLS1's Avatar
My buddy on hear had that set up w a MS4 cam stock 853 heads LS6 intake, Lid Threw a 6spd and stock 10 bolt rear car made 421whp 400Tq on a Dyno jet
On the Same dyno My self w MS4 cam kit Ported Fast 102 Intake w 92mm Tb blah blah blah ...........check out sig
Car made 402WHP
Threw a 4k stall Th400 and a 9in rear
Old 06-07-2011, 09:21 AM
  #40
Advanced Induction's Avatar
Smile
Converse to the typical route, we can simply CNC/refurbish your stock head and you can retain the factory camshaft. If you are attempting to maximize area under the curve below 6krpm, then running a larger cam shaft may not be the ideal route. There are labor advantages to not having to swap the cam as well.
Quick Reply: Is 400rwhp and 400rwtq possible w/ stock heads?
