H/C swap.....no oil pressure
i just finished my H/C swap, new timing chain, oil pump, elec. fans, etc.
i started it up.....it fired right up, after about 5 sec. i got oil pressure (about 35psi) it ran for about 1-2 min and i lost oil pressure. i shut it down.
i checked my fluid, i added 1/4 quart of oil. no leaks. after sitting for 5 min, i started it again and let it run for about 20 sec. still no oil pressure.......the low oil pressure check light came on.
the only thing i can think of what's wrong is the oil pick up tube didn't seat all the way once i installed the oil pump. i dropped the oil pan down 1/2" to get to the one bolt and the tube and all seemed to fit back all normally.
any advice? thank you.
i'm going to go ahead and pull the intake again to inspect. i'm not looking forward to dealing with that pulley again. i was hoping it would be a good while before i had to mess with that.
also, the low oil pressure warning came on in the message center. does that take the same reading from the oil pressure gauge?
i got the pump off again. before i pulled it, i got my head up in there and pushed down on the tube, and it was all seated in good.
once i got it out, the ring looks OK. since i have it out, i'll go ahead and try and find a new one tomorrow. i have the green one. i noticed in some search threads people have talked about other colors. which one is the best?
i'll hook up my mechanical pressure gauge tomorrow. this is getting me worried to keep starting it up without pressure.
GOT OIL PRESSURE!!!!!!!!! i got so much oil pressure, it's not even funny. about 50 psi at cold start.
this morning i put in a new O ring. also changed my cam retainer plate.
I HIGHLY SUGGEST CHANGING OUT YOUR O-RING EVERY TIME YOU TAKE OUT THE PUMP. it's only $7.
thanks for all your inputs.
okay, thanks.
the green one was originally in. i went to the dealership to get a new one and cam plate. i asked the sales guy if he had diff colored ones, but he said red was all he had. i obviously took it.
