Hesitates after H/C
I called the tuner and asked him and he said that was normal for a H/C car. It may be but I just wanted to get other opinions and check anything if needed. I've driven in other cammed cars and didn't feel this at all.
Thanks!
I've said this a number of times but I'm going to repeat myself. A dyno tune isn't about driveability. It's about wide open throttle tuning and it is generally used as a tool to separate customers from large sums of money to provide a simple dyno sheet.
Driveability issues are solved by doing cold starts and setting those parameters and doing stop & go driving and logging the data to make adjustments.
A full proper tune takes time - lots of time.
A dyno is a tuning tool, if someone had a car they raced on race fuel and also used it say as a weekend driver, they may have a twin tune set up in the computer so they could switch to pump fuel.
You don't have a street tune & a dyno tune.
One or two WOT pulls are what a whole host of people mistakenly refer to as a dyno tune because it has been marketed as such by a bunch of posers.
btw i know exactly what i was trying to say and couldn't have said it better. a dyno tune is a dyno tune, then you tune it some more (tweak it) so it has good street manors as well, not just all out power tuning.
It's a well known tuner around here who mainly deals in LSX cars, and I think they are a sponsor here.
The same terminology Down Under has very different meaning, eg. "Street Tune". He's referring to the usage context, while you're talking about the methodology.
"Two cultures separated by a common language."
And you might also have looked into part-throttle dyno tuning before you fully exposed your own ignorance. Too late.
It is not normal to do that on cold starts
