Are Injectors necessary for EPS cam only 222/222 115 +3???
2002 WS6, m6, all stock outside of a lid,suspension, and a GMMG catback.
I believe the stock fuel injectors on an 02 LS1 were 28lbs.
The camshaft going in as stated in the title of the thread is an EPS 222/226 .597/601 lift i believe at 115+3
Is it absolutely necessary to buy new injectors. I WILL NOT be doing headers or heads.
All of my parts came in today and I'm pretty much ready to drop my car off at the shop.
Thoughts???
Thoughts???
Restricted User
Thoughts???
Thoughts???
ok i'll let the shop know to hold off on the injectors. And I can't do headers legally because... I live in the great state of CA
Thanks for the input guys
Thoughts???
Thoughts???
Pick another with more exhaust split like CheaTR or derivative.
Nobody is doubting what can be done. What is your duty cycle currently at with your stock injectors? What is the recommended maximum duty cycle of your injectors? At what duty cycle does the rate of injector failure increase beyond what someone considers average or accepted failure rate? These are actual questions we should be answering to help this poster find what he seeks. Not "it should be ok".
I know my stock injector duty cycle with a 220s cam, I know the SVO 30s duty cycle I replaced them with, and I know what my 42 pounders are at now with a slightly different setup but still cam only. Where would you like me to start?
I personally talked to Geoff at EPS for over an hour and a half over two days and this is what he recommended even with stock manifolds considered. I'm sure I'll be fine.
The cam is actually a 222/226, Do not go off the numbers in the title of the thread. I messed up when i typed it. The correct specs are in my first post.
You might want to check your duty cycle. I have the same cam and logged the car at the track. 99% duty cycle. Got my injectors re-sized by FIC. Will get them in the car soon. My car is a 2002 Z/28 that came with 28 lb injectors stock. I'm willing to bet you are out of injector.
Always always always check duty cycle! its easy to say that u will stay cam only until u get bitten by the mod bug again. i said i wouldnt by another fbody. wrong lol. i love em
