LS1 to LQ4...what all is needed?
I want to swap in a 5.3, 6.0 or LS2 if I can get a good enough deal.
I haven't decided yet if I am going to put forged rods and pistons in whatever I get, or just re-gap the rings and hone the cylinders and have new bearings installed.
I a going to put 317's on it with my current comp 918's, chromoly pushrods, LS7 Lifters, and 227/224 114lsa cam. I may put new springs and lifters in, will decide when the time comes.
This will have my PTE76GTS huffing through this motor also. I'd like to have my intake and TB P&P and add new fuel rails and adding a bigger feed and using my old feed as the return and moving my inline walboro 255 to my fuel tank with my other 255 and put it on a hobbs switch. I hope these fuel mods and my current mototron 60# injectors that I can hit 800+rwhp with race gas and 675-700 on 93. I'd add a Eboost2 to allow a high/low boost setting.
My question is, aside from the motor, heads, and front and rear covers what all do I need?
Can I mount my F-body accessories on any of these motors with the f-body brackets? What do I need in the way of making the accessories work and keeping all the accessories where there are now(stock locations including a/c).
I know I will also need head gasket, intake manifold gaskets, oil pan gaskets, timing cover gaskets, rear main seal, and I am forgetting a lot more too I'm sure.
Do the LS3/L76 intakes flow better than the LS6 intakes? If I go with a LY6 or LQ4 and they indeed flow better I may look to trade mine, or if it's going to be minimal or the same I'll keep my LS6 intake and have my TB ported at the least.
I know I will also have to have the car re-tuned once it's done, but it should be able to start up at least correct? I know it will be lean due to added displacement, but if I stay out of boost I should be able to get it to PCM4Less which isn't far from me.
I am also going to change to SD and add a 3 bar map sensor while I am at it. Another question here would it be easier or better to get the computer from whatever motor I get, or finding a 99+ F-body PCM...? I could also get Frost to put a base tune in whatever PCM I went with while I am getting the motor ready and then pop it in whenever I'm ready to fire.
I know this is a lot, but this is what I have come up with so far. Let me know if you guys think anything needs tweaking or revising to what you would do, or what would be the best way to do it.
Only thing that had me worried was I have seen some people with lQ4's and they had their alternator mounted up high and on the passenger side, like with truck brackets and accessories not f-body.
Will I need a LS2 waterpump or will a LS1 water pump work?
All your F-body accessories will change right over. You will need to decide if you want to drill and tap the LQ block for the third alternator bolt or not...some people do this, and some don't. I didn't, and have been running like that with only two bolts for months with no issues. All the accessories bolt right up in the stock location just like on the LS1.
Your wiring harness, computer, and all sensors will work on the LQ motor. If you get a newer than '05 LQ motor, the reluctor wheel may be the wrong tooth...you need a 24t. All the older LQ motors have this already. The only other thing you will need to procure is an LS oil pickup tube, windage tray, and oil pan.
It is, quite literally, and drop and bolt in swap. Fits like it grew there.
I had a brain fart, duh 317 heads are cathedral port heads.
I am going to forgo the LS2 or 05 and newer 6.0 just for ease of drop in and go.
Good to know about the accesories.
Knowing the accessories work is really spurring me on to do this soon since it is so easy. Main thing I was worried about was losing my a/c due to something not being right. I have heard that the pulley on the crank sticks out further on the truck blocks, I have a good 1-2" if not more clearance between my turbo and crank pulley...will that be enough room with the truck snout?
I'm guessing my LS1 F-body oil pickup tube, windage tray and oil pan will all swap over too correct?
Boy this sounds so easy that I will have plenty of money for a forged rotating assembly, or just get a low mileage long block with no accessories and do a hone, new bearings and re-gap the rings for boost.
I think I am going to try and pick up a computer along with the motor I get because I have the crappy 98 pcm still. I want to change to SD and use a 2 or 2.5 bar MAP sensor so I need a 99+ newer PCM. I'm guessing I can use the truck computer in my car since I have a manual VB auto tranny no abs, and no traction control and my speedo get's its signal from the rear abs sensor.
Sounds like a good weekend project for me and a couple buddies!
I am going to keep the stock stroke and use my oil pan, pickup and windage tray. I've also got a Melling H/V oil pump i'll swap over too. I'm gonna put a electric water pump on there while I am at it, new fuel rails and run a new feed line for my fuel and convert the old feed to return. I guess I'll need to modify the fuel hat to accomodate both fuel pumps in tank and get that hobbs switch.
The most I'm going to do internally is put forged rods/pistons in it. Stock crank, new bearings and if I forge it I will go 370. If I don't forge it I will just have it honed, re gap the rings and have the heads p&p with a valve job.
I just hope I hit my 830+ rwhp goal on 110 at 18psi and 650rwhp on 93 and 13psi.
I hope all this with my 76GTS and 60# Motron injectors and dual 255's get me to 800+rwhp on straight 110 and 100%meth and 18 psi. Hopefully I hit 650-700rwhp on 93 and meth with 13 psi.
