can't crank motor over
Old 08-29-2011, 05:29 PM
aAZz's Avatar
Default can't crank motor over
so before i took the motor apart i was able to turn the crank by myself with my hands. i put a cam and put the harmonic balancer on the block and i tightened the bolt and the motor wont turn over. i need to turn it over since i rebuilt the block i need to tighten up the rod bolts that i didn't have space to get to. my mindset was that since it was easy to turn it over i could wait till i got the harmonic balancer on and then just turn it over through there to get to the bolts. any help guys is appreciated
Old 08-29-2011, 05:56 PM
Darkman's Avatar
At the risk of stating the obvious - do not force it to turn.
In what state of assembly is the motor? Are the pushrods/rockers in place or just the crank?
Old 08-29-2011, 06:13 PM
aAZz's Avatar
everything is in. the heads the rockers/pushrods/cam everything except the oil pan
Old 08-29-2011, 07:07 PM
parks450's Avatar
I could never turn my motor over by hand with everything put together. I had to use a wrench...
Old 08-29-2011, 07:32 PM
aAZz's Avatar
I tried a wrench as well and nothin
Old 08-29-2011, 08:37 PM
getusumws6's Avatar
are the spark plugs installed? Take them out or loosen them, this should Relieve a lot of pressure.
Old 08-29-2011, 08:41 PM
aAZz's Avatar
No spark plugs on yet
Old 08-29-2011, 08:50 PM
getusumws6's Avatar
Did the motor turn over BEFORE you put the balancer on ? This is how I read your first post.
Old 08-29-2011, 08:54 PM
aAZz's Avatar
no I said I could turn the motor before I tore into it sorry. Now I cant
Old 08-29-2011, 08:56 PM
Darkman's Avatar
Did your rebuild include the main bearings?
Old 08-29-2011, 09:27 PM
aAZz's Avatar
Yes and pistons do not have new rings
Old 08-29-2011, 10:27 PM
parks450's Avatar
will it spin either way at all?
Old 08-29-2011, 11:38 PM
aAZz's Avatar
Nope neither way
Old 08-30-2011, 12:34 PM
aAZz's Avatar
Any advice? lol
Old 08-30-2011, 12:39 PM
black00ssFL's Avatar
So this is being done in car? If you can't move it either way at all, then I'm gonna say that it's a clearance problem with the main bearings.
And just to state the obvious...assuming you're doing this in car. Is the tranny reinstalled and if so is it in neutral? Did you use a flywheel stop or something similar and if you did is it still installed?
Old 08-30-2011, 01:21 PM
aAZz's Avatar
No the motor is outside of the car in a stand. How would it be a clearance with the bearings?
