how many of you DIDNT degree their cam in???
Originally Posted by 30th t/a
ok cool. I do have a experience LS1 person that installed my cam and i just dont want to drive 4.5 hours to rapid motorsports to find out its off a tooth and making crappy numbers.
thanks guys
thanks guys
As for degreeing, personally, I have never NOT degree'd a cam (just did one a few minutes ago in fact). Lots of people install it and call it good. But it's always good to check! That's why we degree everything at HPE. We would never ever consider trusting a parts manufacture to do their job the way they were supposed to.
Chuck
Super Moderator
There is no need to degree a cam unless you have an adjustable timing chain setup. There is only one way the cam can go in the engine otherwise. And gettting the gears lined up is just a matter of lining up two dots. This is not a small block chevy motor. It is nearly fool proof.
best reply yet.... ive NEVER used a degree wheel, and ive put in some pretty big cams.
mike
To degree, or not to degree. That is the question.
I'd say it depends on your goals. If all you care about is a nasty lope at the drive in, don't bother to degree it. If you actually race and care about the results, you would be a fool not to degree it. I've never seen a cam that was exactly right on, although the do seem to be better these days. But even if it is right on, you may want to move the ICL to work better with your port job on you LS6 intake or whatever.
Super Moderator
Well, OK. But if you do this, and don't like the way things line up, then you are getting another cam. There is nothing you can do about it except buy an adjustable timing setup. Otherwise, you are completely wasting your time.
http://www.cranecams.com/pdf/16g.pdf
I bought an adjustable timing set and didnt degree it, but next time I will.
Well if the dots are lined up on your cam install, degreeing the cam will only assure that the manufacturer ground the cam to spec. The cam card should also verify this. When I spoke to FMS about purchasing my cam they said once it's back from Cam Motion they degree it to make sure it's ground correctly to spec so no need to degree it for myself.
Degreeing in a cam will tell you if your cam is ground correctly, and give you exact specs with your setup. It is easy to not line the dots up right when doing a cam swap, but degreeing in the cam isn't really the answer to not doing that. As long as your at TDC and you line the dots up your fine.
Originally Posted by 66ImpalaLT1
You can drill it out and put an offset bushing on the pin. Thats how I've seen SBC's degreed without a adjustable timing gear.
But, as I said in the first message, you don't _have_ to degree a cam. It depends on your goals. If you are serious about going fast, you almost have to, but otherwise it is a waste of time.
