Tap and die crankshaft threads? Rookie mistake w/ crank pulley removal
Damn. Didn't even think about that mightybird. You guys rock. Right now I'm on a mission for some tools though. Typical 3 stage tap kit and a thread chaser for M16 x 2. I hope I can land the tools locally from Grainger or a place like that. I've tried Home Depot, Advance Auto, Sears, and the biggest they have is M12
Get a bolt from a hardware store and make a thread chaser. Not hard to do. Use a new bolt since crank bolts are TTY, and a used crank bolt will have some deformation along its thread/length.
I think I'd try doing what Mightybird and Bluestreak have suggested before buying a $45 tap that you'll only use once. I'd use a socket head cap screw because they're generally made out of harder steel than hex head bolts.
Cut grooves in it like a chaser/tap looks so the metal has somewhere to go as the thread material is cut/straightend. You can use a dremel, I many times have used a bench grinder and just grinded down two sides of the bolt then spray lubricant on the bolt and go nice and easy with it until the threads are cleaned up.
Go in a little bit then back out and clean up the bits of metal inside the crank and on the bolt, then go in a little further and repeat until you have fixed all threads.
You can go rent a pulley puller that bolts to the balancer and has a fat tip on it that won't go down inside the crank snout to pull the pulley back off. If you can't get that set up to work use a 3/8" extension to bottom out inside the snout of the crank and press off of that.
And if you try to press that pulley on by hammering on that bolt you will mess up the threads again so you need to get a pulley installer also. People sell them on here.
You can try heating the pulley to 200 degrees or so, maybe up to about 240 so that it slides over the crank easier. Sand down the inside of the pulley and clean the crank snout real good, then put some light lubricant on the crank snout and inside the pulley. Then when you are installing the pulley put a little oil on the bolt threads, the bolt head, and on the contact surface of the pulley to the bolt and it will also help the install since metal wont try to grab the other metal surface.
Restricted User
If you pound the balancer on with a hammer a little bit, you should be able to pull it the rest of the way on with the bolt and an impact right? Since you should be on enuf to where the threads are in a ways.
This balancer is keyed. I have the puller installer tool. I was talking $45 for a tapping bit instead of grinding a used balancer bolt to home make a tap. =) Once again you guys are awesome. Thinking a bit about this more. Since I jacked up the threads with a socket extension, there is most likely 4 corners of the threads that are pushed in a chewed.
Before ordering that tap, please check this out. I couldn't remember what the harmonic bolt size is....was it a m16x2?
I order from these folks often. You won't believe the prices, and everything I've used their tools/taps etc on have turned out perfect.
http://www.tools-plus.com/irwin-1756.html
If this isn't the exact part size, call them with what you need.
Shipping is $6.50.
Located in Waterbury CT.
Shipping is $6.50.
#34
On second thought, the tap shown in my first post may be just fine.
Call them and connect to customer service. These guys will tell you if the inexpensive bit will be appropriate for your application.
Heck, I see that the brand is Irwin...good stuff.
Did I mention that you'll have the tap in a couple of days?
#35
You know, I've been thinking about the operation of a tap on this kind of issue. The tap would have to be thin enough at the tip, and tapered at the correct angle in order to insert it, then have threads match up to the good, existing threads within the crank.
If the threads of the tap & the threads of the crank bolt hole engage, then the tap should do its' job and correctly recut the area which is damaged.
If the tap is not able to be inserted far enough to engage the good threads, then you won't be allowed to redo those damaged threads.
The tap cannot be allowed to just begin cutting at the top of the bolt hole, because those newly created threads may or may not meet up with the existing good threads within the crank.
Just a thought or two.
#36
To all my lovely friends who have been helping me,
Good and bad news.
The Grainger tap worked perfect and I got the pulley off as well.
I was millimeters away from starting the oil pump to pick up tube. I dropped it 4 times and had a rag stuffed in there. Each time I was able to get the bolt. On the 5th try I didn't realize the rag slipped and now the bolt rolled into the pan.![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
I have the PA Kmember but I guess I have to lift the motor to remove the pan right??
Good and bad news.
#38
I'm gonna definitely try all sorts of magnets first. It's aluminum but I think ill hit the crank with a magnet. Rookie mistake #2. I was so close.
I really don't want to remove the tranny again.
