Low oil pressure
oil pump O ring has probably been pinched allowing pressure to pass.
Use the search button...read as much as you can about the LS motor from mods to maintenance & all the pit falls the guys have come across....there are many!
All your oil pressures hot & cold, cams, heads, exhausts, manifolds etc.
You have many hours of reading ahead of you & a huge amount to digest....Goodluck
what is the engine mileage and viscosity engine oil are you running?
I would suggest performing an oil pressure test. check your oil pressure at the specific RPM range according to engine model. if the oil pressure is low it is most likely the oil pump.
also make sure to remove the pick up and clean it out, sometimes it can be clogged not allowing it to suck up engine oil. once the pump is removed check the snout of the crankshaft for wear, if the snout that makes contact with the oil pump is worn that may be your cause. there is not enough contact to spin the pump since it is a rotor style pump.
hope this helps
As much info as possible always helps.
you should put the stock oil pump back on and see if your oil pressure changes.
unless your doing some hardcore racing, have a higher capacity oil pan, and dry sump your just setting your engine up for disaster. your gonna starve the bottom end and damage your engine.
what where your oil clearances?they should be on your engines build sheet from the machine shop.
Did you check your oil pickup / tube to the bottom of the pan clearance..?.. put some clay on it and then put the pan back on. to check it. if it is too close to the bottom, it can cause problems. I have about 3/4" on mine.
I would also check the relief valves (dumb bells in the block) and valve in the pump.
I am guessing this is a alum block. The mains need no more than .002 rods can be .0024 or so.
cam bearings can be the issue but a competitent machinest should be able to handle this. Some cant even get them in straight and this will tighten the clearance up.
My engine makes 60 psi cold idle and 30 hot. The block grows a bunch and if you don't have the ability to overcome that with extra volume you will have issues
Tim
