Zero Oil Pressure & metal flakes
I had three episodes of decreasing oil pressure. The first time, there was gas in the oil. I changed the oil & filter, and pressure was restored to about 28lbs, hot.
The second time, pressure went to 4-8 lbs. The engine was shut off, then let sit for a few minutes, then restarted. Pressure went back to 24 lbs hot.
The third time, there was some clatter. I looked down at the mechanical gauge to see 'zero'. I was around the block from home, so I feathered it & parked it in the garage.
Inspecting the filter, there is a small sum of glitter-looking, small bits. The metal is non-ferrous/non-magnetic.
I changed the oil pump, thinking that the relief valve wasn't functioning.
An aborted attempt was made to inspect the pickup screen, because the pan couldn't be moved enough to gain access to the screen.
After changing the pump, I cranked the engine in an attempt to see if pressure was restored. It wasn't
So, now I know that the engine will have to be pulled so I can check all bearings/parts.
Here are my questions...1)Are the bearings in these engines non-metallic?
2)The brightness of the metal tells me that it could be aluminum...is there anywhere on the aluminum block that can become abrased?
3)If I inspect the crank caps & rods, are all of the bolts TTY? (they have to be replaced)
4)Is there a how-to video about rebuilding LS1 blocks? I'm going to do everything except the machining, of course. Thanks.
There is a video somewhere, but you really need the GM service manual.
I already have the ARP's.
The 'white metal' of the bearings that Joecar mentioned, must be what I'm seeing in the oil.
I'm curious: What oil & filter were you using? How did you inspect the filter, did you cut it open?
The heads have all new parts/lifters, rockers, pushrods, valvejob.
Castrol 10w-30 conventional & Fram extra guard.
I've always felt from day one that the oil pressure was low, compared to that of others here. The failure might or might not be connected to this.
My motor I just built guy said it lost oil pressure and he shut it down, instead of just slapping a new pump on I pulled the engine apart and found all the lifters damaged and one completely destroyed, and a ruined camshaft.
That metal I see is the babbit lining. imo
I learned that even though an engine has little mileage, that that doesn't ensure that seals on the (old-original) waterpump, or the pwr steer pump, etc are good after sitting around unused for a few years.
The bottom end was checked at the beginning of the year and was found to be like new.
The symptoms pointed toward a moving cam bearing, or possibly the relief valve in the oil pump.
After replacing the oil pump, there was zero pressure.
I think I'm going to start at the top of the block and work my way down.
