How much do the lightweight valves benefit power? Im looking to buy some 243s and put in a small cam but are the ZO6 heads worth double the money of the other 243s?
The lightweight valves may be worth more if you follow through with the lightweight concept in terms of valve springs and other components. Many builds negate the advantage of the lighter valves by installing double springs.
I would be running a beehive, nothing about my plans would require a dual spring. Planty of guys are making 400 with 220 or 224 cams and stock LS6 heads, thats all im looking for now.
