overheating need help plz
Old Dec 29, 2011 | 06:40 PM
atkinsson's Avatar
Default overheating need help plz
2000 ta car overheats starts throwing water threw resovor at 210 and car starts to heat up, if I turn AC on both fans kick and car never overhearts .But if I turn AC off and run the car it will begin to throw water and fans never come on. The Problem cars fans don't come on when AC is off. New radiator cap new resovor. Any help would. Appreciated. It thanks
Old Dec 29, 2011 | 08:16 PM
atkinsson's Avatar
If I turn on ac so fans can come on, it won't overheat. if I can figure out y the fans don't kick on with out ac then I fix my problem... How can I check if my pcm is good anyone? And its got a new cooling temp senser to eleminate that.
Old Dec 29, 2011 | 08:22 PM
atkinsson's Avatar
It does have a autozone cap. It might be crap
Old Dec 29, 2011 | 08:31 PM
chrisfrost's Avatar
There are alot of possibilities as to why the fan does'nt turn on ,,,,,but the most likely causes are in order 1. 1 of the fan fuses 2. 1 or more of the fan relays ,,,,,I believe those cars have 3 fan relays controlling 2 fans 3 fan switch in 1 of the heads (looks similar to temp sender) and actually may be the sender and computer that controls the cooling fan in question 4 cooling fan motor is bad You can check You're PCM by using a wiring schematic and locate the wires from the PCM to the fan relays and check for power and if You have a repair manual for the car in the engine cooling section they tell what the different resistances are through the temp sender for different temps ,,,,,so for a temp over 200 read the coresponding resistance and get a resistor of that value or really close and unplug the plug to the sender and put resistor in touching the wires ,,,,turn ign on and check for 12 volts as described earlier .
Old Dec 29, 2011 | 08:32 PM
Paul Bell's Avatar
That's MISTER MODERATOR
The fans usually come on in low speed-both running in series. This seems to not be working in your car. A third relay does it and is fed with a 10 amp cooling fan fuse under the hood. The 40 amp cooling fan fuse under the hood is for the high speed. If both fuses are good, swap around the relays.
Old Dec 29, 2011 | 08:40 PM
chrisfrost's Avatar
If the cap is fairly old replace it ,,,,,,,,but if the weather where You're at is kinda cold then You probably have an issue like head gaskets or cracks and/or warpage ,,,,,,,,,how far can You drive with the a/c on ?
Old Dec 29, 2011 | 08:41 PM
atkinsson's Avatar
What's oem cap pressure?
Old Dec 29, 2011 | 08:48 PM
chrisfrost's Avatar
Either 16 or 17
atkinsson's Avatar
Um I went 10 miles other day with ac on no problem cuz fans were running but if I turn ac off where fans stop then it will heat up in under 2 miles . Im going to be working on it checking dif things u all suggest my 2001 camaro works fine so Ima swap all 3 relays see if it changes anything ... I unplugged temp senser turned car on and fans were on hi don't that mean pcm is working.
Old Dec 29, 2011 | 08:50 PM
atkinsson's Avatar
What happens if fans r not running gets hot thows most water then fans can't stop it from heating even if they were on ..
Old Dec 29, 2011 | 08:51 PM
chrisfrost's Avatar
Yes GM PCM's are very durable and that would be the very last possibility to the fan prob
Old Dec 29, 2011 | 08:52 PM
chrisfrost's Avatar
That would be assuming You turned engine off before temp reaches 240 or 260 or You would'nt ?
Old Dec 29, 2011 | 08:53 PM
atkinsson's Avatar
I'll be working on it tomarow updating this thread as I go... Thanks for the help.
Old Dec 29, 2011 | 08:54 PM
chrisfrost's Avatar
No problem ,,,,,,,,,that's what this whole community is here for .
Old Dec 29, 2011 | 08:55 PM
atkinsson's Avatar
Ya I turn it off before .
Old Dec 29, 2011 | 08:58 PM
atkinsson's Avatar
The auyozone cap has a 18 stamped on it I figure maby cap is too week and let's all water out too soon. Tomarow ill try my ss cap on it its a stoker
Old Dec 29, 2011 | 09:02 PM
atkinsson's Avatar
Ima pressure test sys
Old Dec 29, 2011 | 09:03 PM
atkinsson's Avatar
I'm out be back tomarow
Old Dec 29, 2011 | 09:04 PM
chrisfrost's Avatar
Just a little FYI aluminum heads warp way easier than iron heads so to be as safe as possible You want to either leave it running if it is'nt too hot like maybe 220 max ,,,,,leave it running and take cap off with a rag and be careful just take it off slowly then pour water and/or coolant in stopping for 3 or 4 seconds say every pint or so so You don't crack anything but if it's hotter shut it down for sure wait a few min the carefully remove cap and very slowly add water/coolant ,,,,,,,,,,with engine not running there is more risk of cracking something so maybe every half pint stop adding for 5 sec or 7 sec and watch out cause it may spit violantly out of hole .
Old Dec 29, 2011 | 09:17 PM
Paul Bell's Avatar
The cap pressure has nothing to do with the fact that your fans aren't coming on.
At highway speed, the fans do not run as the car's motion alone puts enough air through the radiator to keep things cool. Unless the A/C is on or it's running hot.
