g5x3 cam and texas speed 5.3 heads. Good Combo?
I have a 98 LS1 with a G5X3 cam with 114 lobe seperation and .610" lift. I'm thinking about getting the Texas Speed 5.3 stage 2.5 heads with the 58cc combustion chamber (http://www.texas-speed.com/p-1172-pr...ted-heads.aspx). This is going to be a street car that gets driven on nice days in the summer and will see the track a few times. I want something that is still streetable.
With stock pistons I believe this will get me around 11:1 compression correct? These heads should be fine with pump gas right?
Also, I assume I will have to flycut my pistons with these heads?
Let me know your thoughts on getting the heads.
LS1Tech Premium Sponsor
If you can give us cam specs we can give you a good idea about what will and will not clear with these heads!
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic110569_2.gif)
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
That much cam and 5.3's milled to 58cc you will have to flycut your pistons!
__________________
507rwhp/445rwtq
1997 WS6 Trans Am M6- 3.42 gears, 315 ZR's LS1 ( out of a 28K Trans Am) Texas Speed stage 2.5 5.3 Heads (milled) LG G5X4 Cam Pace 1-3/4 Headers, Pace Y-pipe, TSP Rumbler Cat back exhaust FAST 92/90, LT1 WS6 Ram Air Lid Comp Trunion rocker upgrade, 7.350 pushrods, LS7 lifters Underdrive pulley Turn One Power Steering Pump MR12 Race Fuel, 28* Timing 12.0 A/F
