Rear main seal - 89060436 - which way to install?
Old 02-19-2012, 01:23 PM
66 BADBOY's Avatar
Default Rear main seal - 89060436 - which way to install?
Hey guys,
I am putting a new rear main seal into my rear cover (engine is being assembled, so its out of the car).
Reading the paper that came in the bag, it says that the seal should say "THIS SIDE OUT" somewhere on it. The problem is that mine does not say that anywhere on it.
Anyone know which way to install it....is it installed so that the lined and tapered opening get wider as it faces the trans? Or as it faces the engine?
Thanks!!
Old 02-19-2012, 03:33 PM
sjsingle1's Avatar
i read that same piece of paper......and thought............where the hell is the.....THIS SIDE OUT........never did install it.......does any 1 know?
Old 02-19-2012, 03:48 PM
kevhill85's Avatar
Funny.. I am at the same point with my rear main seal.. Trying to install my to..
Old 02-19-2012, 03:50 PM
davemfl's Avatar
On most seals the wide taper places the front of the motor.
Old 02-19-2012, 04:14 PM
kevhill85's Avatar
Ok what side face the block?
Photo 1 or photo 2
Old 02-19-2012, 04:22 PM
davemfl's Avatar
ok, it's kind of hard to see with these pics, but whichever part of the rubber seal is the smallest diameter would face the block. Think of it as pressure forcing against the seal and expanding it.
Old 02-19-2012, 04:34 PM
ABQ99TA's Avatar
old pic but it works.
Attached Thumbnails Rear main seal - 89060436 - which way to install?-rearseal.jpg   Rear main seal - 89060436 - which way to install?-rearseal2.jpg
Old 02-19-2012, 04:43 PM
66 BADBOY's Avatar
Photo 1 or photo 2
I ended up going with photo #1 facing the block (inside of cover) due to this thread that I found. The first post is a pic of it installed right from GM as a new cover/seal assembly:
https://ls1tech.com/forums/generatio...-opinions.html
Thanks for the pic, but that is actually the older style setup.
Old 02-19-2012, 05:02 PM
kevhill85's Avatar
Thank u guys.. Sorry for the hijacking ..
Old 02-19-2012, 05:08 PM
davemfl's Avatar
Yup. that looks right.
Old 02-19-2012, 05:11 PM
autogeek23's Avatar
thanks for posting this. i am also replacing my rear main seal, tomorrow. but i figured i would just see how the old one came out.
Old 02-19-2012, 05:58 PM
Hackscamaro's Avatar
it will say this side out on the seal if its a gm seal its just had to see using a pen light helps but you always face the open lip of the seal towards the motor as the oil pressure will expand the lip and seal it against the crank. you will know if you put it in backward when you prime it or start it. it will **** oil
Old 02-19-2012, 06:02 PM
66 BADBOY's Avatar
The weird part is that mine had a different part number on it compared to what the bag said (the bag part number is the one I used in the title of this thread).
The actual stamped number was 12602972.
And trust me, I covered every square inch of that sucker with a magnifying glass and flash light. No THIS SIDE OUT anywhere. I just compared it to the one in the thread I posted and did it that way.
Here's the pic I found of the new from GM cover plate with seal already installed. No idea why the pic turned gigantic, but here it is:
Old 02-19-2012, 06:06 PM
kevhill85's Avatar
I bought a felpro gasket kit.. I have looked and looked. All I found was numbers and dots
http://www.summitracing.com/parts/FEL-BS40640/
Quick Reply: Rear main seal - 89060436 - which way to install?
