162k cam swap
Old 03-28-2012, 12:40 PM
cory32690's Avatar
Default 162k cam swap
Gettin ready to do cam swap on my 162k formula a4 was wondering if u should replace my factory oil pump..at idle on full temp it's a 40-50 psi and close to 80 full throttle
Should I go ahead and replace because of mileage or keep it and get new o ring..also going with a double roller chain will a certain oil pump fit better
Old 03-28-2012, 01:23 PM
Troy5061's Avatar
Its kind of a crapshoot either way, your oil pump is probably fine but most will say to replace it. Im putting an oem LS6 oil pump on my 383 build. I bought it from ws6store for $105 and it came with an o ring. As far as the chain goes some double rollers require oil pump spacers and clearancing of the timing cover. Im using new oem gears and an LS2 chain.
ds98formula's Avatar
I would get an ls6 oil pump. It's only 100-150 for the added security
Old 03-28-2012, 01:32 PM
VandykeT/A's Avatar
I would swap pumps and just go with a LS2 chain. Use the money you saved no going double and buy the pump.
Old 03-28-2012, 06:14 PM
cory32690's Avatar
I already have the chain and it comes with spacers I was thinking about the slp oil pump I would assume sense
they offer it with there double
Roller
Old 03-28-2012, 06:38 PM
TransamGCS's Avatar
Roller
if you have a SLP double roller already go with the slp oil pump its machined to fit the slp double roller chain you wont need to use spacers
Old 03-28-2012, 07:51 PM
cory32690's Avatar
Would a jp performance chain fit the same if u no thank u
Old 03-29-2012, 05:49 AM
TransamGCS's Avatar
I think the slp double roller is a jp chain i would call SLP and tell them what you have, the SLP oil pump i think is a milling they do modify either the pump or sprocket or it might be the collar that comes with the kit that makes it all work not really sure. i bought the kit for my build and every thing worked out great with no clearance issues on the front cover.
Old 03-29-2012, 06:36 AM
Tainted's Avatar
I would for sure change it. With that many miles id be replacing everything I could while I was in there.
Old 03-29-2012, 07:06 AM
cory32690's Avatar
Ok thanks for info..and that's the game plan replace everything I can while I'm in there
Old 03-29-2012, 08:15 AM
Internet Mechanic
BlackScreaminMachine's Avatar
There are some out there that argue on pumps due to using ported LS6 or HV pumps that end up with Pressure issues. Interesting thing so I am not going to tell you not to do it but just monitor it once it's in and see what it is running cold idle, hot idle, and under load conditions.
I ran into this when I did a swap @ 30k miles and worried bout stock 2002 oiling and was recommended not to do it and never any issues @ 47k. Oil cleaner then clean so MAYBE when I either put a different stick in there or look at a 402+ CID motor will change the oiling system.
Just IMO.
