PTV how about PTSpark plug!?!?
I went ahead and confirmed with clay that they were new and fresh marks. Sure enough they are. There is a large knot for the spark plug threads and I think I should be OK to grind some away but wanted to see what others had for ideas. Biggest thing is will be I OK to use these heads.
Here is where it is contacting on the piston.
I didn't have a head gasket so that is another .051 of clearance but if I am lucky that currently gets the piston to not touch the head I still need some clearance for safety!
Here is the head with clay on it.
I think the gasket should get me so they don't touch so that means I would need to take .03-.05 off the spark plug boss. Seems insignifigant enough but maybe I am wrong.
These heads will be on the engine no more then a year. I have another set of 317s that are going to get ported and polished of possibly look into a better set of heads. Not sure but regarless these heads are temperary. The only down side of not taking it off the piston I will need to do the same to my other set of 317s. I will address the issue then and possibly look deeper into cutting the pistons.
Thanks for the ideas and help.
