Anitfreeze leak fromthe back of the head, What can it be, Please help!!!
Old 04-04-2012, 11:07 AM
Ronny_02_WS6's Avatar
Exclamation Anitfreeze leak fromthe back of the head, What can it be, Please help!!!
So I just putted the heads back on the car after valvespring and lifter change LT/ ORY, (for very soon cam), AIR removed, and when I started the car, antifreeze is leaking down from the back drivers side head runs all the way trough the bottom of the Transmission, it was mixing oil with coolant as well, I took the driver's side head off and cleaned it it and installed it again with new bolt and gaskets and started it up again and the same thing happened, What can This be, is frustrating doing extra work for same result???
Old 04-04-2012, 11:19 AM
KCS
Moderator
KCS's Avatar
Steam tube posts?
Old 04-04-2012, 12:46 PM
Originally Posted by KCS
Steam tube posts?
Would that make the coolant mixed with oil???
Old 04-04-2012, 12:54 PM
NY02ws6's Avatar
Nope, but head gasket, cracked head or cracked block would...did you torque the head bolts correctly? Did you check the heads for warpage? Did you clean ALL of the coolant out of the head bolt holes in the block?
Old 04-04-2012, 01:10 PM
Well, gaskets are new, I ensured that the bolt holes where 100% dry, I spent a bunch of paper towels and blew air also, the head looked clean but not sure about warpage though.
3rdCoastPowerSports's Avatar
coolant crossover tube or block off plate. if you R&R'd it recently. did you install a new coolant crossover tube gasket? did you torque the bolt down to 106 in/lbs?
Old 04-04-2012, 01:31 PM
NY02ws6's Avatar
Are you sure you torqued everything correctly? If the same head leaked twice I would definitely have checked it and the deck for flatness before reassembly the second time. All you need is a straight-edge and a feeler gauge.
Crossovers won't put coolant in the oil.
Old 04-04-2012, 01:38 PM
i guess i didn't read close enough. i did not see that he had coolant in oil. i thought he just had coolant coming from the coolant block off cap.
Old 04-04-2012, 01:44 PM
NY02ws6's Avatar
Yea if it was just a leak I would have said the same thing. Leak plus coolant in oil...to me that is either head gasket or the back of the block is cracked. I would lean towards gasket not sealing, maybe warped head?
Old 04-04-2012, 02:25 PM
run a leak down test but i agree, block or head gasket... hope its a head gasket
Old 04-04-2012, 02:27 PM
Thanks for the responses, I will have the car lifted, I will run a test and check with a mirror or something to see where it comes from, Im sure is not the gasket because i did it twice with new gaskets, but if it's the head maybe that would be the excuse to get aftermarket ones, if it's the block I don't wanna know. I have my fingers crossed.
Old 04-06-2012, 11:00 AM
Problem fixed!!!, it was the Coolant bolt of the back of the head towards the intake, it was loose, like the coolant crossover but the back, the pressure test save my life!!!! I was super scared, now I'm back on the road
Old 04-06-2012, 12:48 PM
NY02ws6's Avatar
Good to hear, so how was coolant getting in the oil?
Old 04-07-2012, 03:46 AM
Well the first time it was the gasket and then I took the head off and cleaned the old gasket material with acetone, and it sealed good, then I putted back but that coolant bolt was loose, I changed the oil, did the pressure check and checked the oil and no mix , I tighted the bolt and no more leak and the pressure stayed the same (no psi loss) so lesson learned, pressure test before anything.
Old 04-08-2012, 08:44 PM
burntblues's Avatar
What and where is the coolant bolt?
Old 04-09-2012, 06:44 AM
The one on the back of the head, the bolt was loose, the coolant seal where this goes: http://texas-speed.com/p-2268-gm-ls1-coolant-seal.aspx
Quick Reply: Anitfreeze leak fromthe back of the head, What can it be, Please help!!!
