Crank Snout Had Been Drilled Question
I purchased a used crank from ebay. Upon receipt, I found that the end of the crank has a approx 1" long x 1/8" deep drill bit hole, where the balancer was. The drilling begins at the end/outside of the crank, and proceeds inward toward #1.
It looks like this was done to relieve a balancer, to remove it.
My question is...should I fill this 'groove' with some lead? Or, does it matter, being that the missing material is located close to the center of the rotating assy?
Opinions, please.
Opinions, please.
UNDER PRESSURE MOD
I don't know if you would be able to see that weight difference balancing it. It's so close to the center line, and now much weight could it have been, a few grams maybe? What it looks like is they drilled it the first time, and the pin was too small, so they stepped up to a larger pin to match up with a keyway in the pulley. That's my guess.
It is typically done for centri supercharged cars.
Popular in the Vette world.
Personally I think it's a dumb *** way to do it. But it is done w/o removing the balancer.
Take it apart once, you won't get it lined back up perfectly.
In your application, I think you can leave it be. I don't think lead would do any good except to make it look better.
It could have been welded and remachined while the crank was out.
Another option provided the current width of the area in question, is not too wide. I would to take it to a machine shop and see if they can cut it to the end for a square key way, cleaning that area up.
Most all aftermarket balancers are keyed were the stock units are not.
Then if you ever decide to go FI you will be ahead of the game. Nor would you have to worry about a balancer spinning on the crank. Not that it is a common problem.
