LS1 Degree'n Cam (Intake Centerline)
Ok, I bought the comp cam kit, no instuctions BTW...I used : http://www.carcraft.com/techarticles...e/viewall.html
Following their instructions I tried to degree the cam 3 times,
For intake center line I got:
109 degrees
108.5 Degrees
109.5 degrees
My cam card says the ICL should be 110 deg.
Is that it? I thought I read somewhere else I need to check VE, No?
109 degrees
108.5 Degrees
109.5 degrees
I checked the intake centerline and then checked the cam position at 0.050" lift from the cam card to verify/double check. Also, make sure you lifter isn't hanging in the lifter tray or if not using the tray make sure the lifter doesn't turn, it will throw off the answer.
Do you check more than one piston?
As confusing as this sounds, I tried the initial .050" lift seem to be way off....So I just turned the degree wheel to the applicable degree and on the wheel (Valve open) and checked the guage.
According to the cam card, Intake opens at 4 deg. I turned the engine over and upon initial valve opening at .050" I do get 4 deg. On the closing side its suppose to be 44 deg. I do get that .050" before closing. Is that correct?
What is confusing me is on the degree wheel at TDC the numbers are listed from 360 deg and backwards, but the valve is opening 4 deg @ .050" (because I can count 4 hash marks before TDC). As for the closing, thats where it gets muddy. According to the deg wheel, the intake valve is closing at 224 deg after TDC, but 44 deg in the 90deg markoff in the intake closing section. The numbers match, but my mind is confused.
Dis-appointed to see so few have degree'd a cam...
I checked ICL again, I can't get consistent measurements. The crank adapter appears to have slight slop, thats probably my issue. I got 108.5 and 110.5....
Checking VEs though seem to be on the money. I also checked total lift on both lobes and again spot on.
