228r or polluter for DD
Old May 25, 2012 | 11:46 PM
  #41
14k's Avatar
14k
Yea that's big $$ for the polluter. I'm ballin on a budget lol. I buy a little here a little there. Thanks for all the help.
Like my friend said. Is a stall really needed for the 228? Or just another mod to really wake it up after a cam?
Old May 26, 2012 | 12:07 AM
  #42
sweet99ss's Avatar
Not trying to be a dick, but you friend needs to stop giving you HORRIBLY FALSE advise.. The 228r is a pretty decent sized cam. Without a stall the car will see minimal gains. The stall keeps you in your powerband for the cam. With stock stall everytime you shift it's going to have a huge dead spot. The bigger cam makes power at a higher rpm. A stall is 150% needed. You will knock off more et with a stall than you ever will with a cam. I went from 12.99 to 12.3 from stock stall to a circle d 3400 stall. Not to mention it will be hard to tune, drive like ****, and pull on your brakes like a bitch.... With that cam a minimum of 3000 stall is needed imo. A 3600-4000 for best results. I hope you do not listen to whatever you friend is telling you lol. I promise you won't be happy if you do.
Old May 26, 2012 | 08:08 AM
  #43
14k's Avatar
14k
Na it's all good. I understand.
Old May 26, 2012 | 11:15 AM
  #44
14k's Avatar
14k
Is there a difference in sbc/bbc cams and ls cams? He says 228 sounds small but he's not in the ls game just sbc and bbc
Old May 26, 2012 | 11:43 AM
  #45
The_Bishop's Avatar
Yes, massively different. Stock LS heads flow what 'race' old school heads used to, and that alone is enough to make cams act differently. It's a completely different engine design, so guidelines on what worked in 'old school' motors aren't applicable to modern engine design.
In short, stop listening to him.
Also: Go with a 3600 converter. I have a Yank 3600 SS in my '98. It's a damned good converter on the street.
Old May 26, 2012 | 12:04 PM
  #46
14k's Avatar
14k
Would going stall first need a tune? Or is it just a bolt on that doesnt need one to work but can benefit from it?
Old May 26, 2012 | 12:26 PM
  #47
MikeWS6's Avatar
Get something inbetween like a t2 cam. They get around 400 with bolt ons and are alot more aggressive than the 228r.
Old May 26, 2012 | 01:11 PM
  #48
LeanPocket's Avatar
Get the stall and tranny cooler first, get used to that. DD.. 3000-3200.. street demon 3600-4000. CircleD or Yank, nothing else.
A Cam swap should always be the last thing you do TBH, cuz you need so many supporting mods to make it reliable and drivable. You can't just throw in a cam and hope for the best, thats *** backwards. And you better not be buying to just for the sound, I will personally drive over there and steal your ls1 and give you a junkyard lt1.
and I would contact PatG to spec you a cam optimized for that setup vs a over the shelf cam. If you just absolutely HAD TO HAVE A OFF THE SHELF CAM, torquer 3 112lsa would be a decent cam thats still driveable, or a torquer2 at a 113 lsa if u want to use spray (refer to carter01)
Old May 26, 2012 | 01:33 PM
  #49
flintwrench69's Avatar
Originally Posted by ls1wallen
I have the 228R and 4100 Revmax. I DD it for awhile when my trucks clutch decided to let go. Its a very nice cam. Very tame. But I wish I would have gone bigger. Somthing in the 230's. I hit 382hp 364tq
This is right in the ballpark & what my #s were too. Autos wont be as high.
Originally Posted by FormulaTA327
Ive heard that when you get a stall converter it can actually lower your hp readings on a dyno,
Yep.
so you might get 400 rwhp but it will not show on the dyno.
Nope, not with a stalled auto but dont let that fool ya as long as it runs the times it should at the track.
He's right. I've seen cars run horribly shitty times with a decent cam & no stall trapping 106. Same car would trap much higher with a good stall & stock cam.
Sounds small? Your bud doesnt know anything about LS engines, it would be considered a big cam in a sbc. Its a mid sized cam thats got a wide powerband 1800-6600 rpm & 40-50 whp gain. Add some ported heads later on & you will be well over 400 whp.
This wouldnt be a bad choise either, the T2 has a lil more lift & duration. Not as street friendly as the 228. For a DD I wouldnt go with a polluter.
Old May 26, 2012 | 01:39 PM
  #50
14k's Avatar
14k
It's definitely not for sound although I love it I want the added power and street manners most.
Old May 26, 2012 | 01:59 PM
  #51
sweet99ss's Avatar
Like has been mentioned all through this thread. Get yourself a quality stall in the 3000+ range with a big cooler. And than you can get the cam and get it tuned. Getting a cam first is doing it in the wrong order. You will be fine running a stall on stock tune, but a tranny cooler is a must
Old May 26, 2012 | 02:01 PM
  #52
14k's Avatar
14k
Even running a stall on a frost bolt on tune will be ok?
What cooler do you recommend for 3k+?
Old May 26, 2012 | 02:11 PM
  #53
blubu's Avatar
I've got a new 228R on a 114 for sale.
  #54
sweet99ss's Avatar
Yes it will be fine tell you get the cam. You MIGHT have a problem with it taping rev limitr on WOT runs, but it won't hurt anything daily driving it. This is the cooler I got with my circle d 3400-3600 . My transmission temps have always stayed nice and cool with this cooler.
http://www.summitracing.com/search/?...%2070264&dds=1
Old May 26, 2012 | 02:34 PM
  #55
14k's Avatar
14k
Where did you mount yours sweet99ss? Any pictures?
Old May 26, 2012 | 03:01 PM
  #56
sweet99ss's Avatar
[IMG]http://i983.photobucket.com/albums/a...nnycooler5.jpg[/IMG]
Old May 26, 2012 | 04:17 PM
  #57
sweet99ss's Avatar
how much are you wanting to spend on a converter?
Old May 26, 2012 | 04:19 PM
  #58
14k's Avatar
14k
Idk. Not more than 700-800. Been looking at yankss and some places have them for 699. I'll check the sponsors too
Old May 26, 2012 | 04:35 PM
  #59
ls1wallen's Avatar
Ive had my revmax stall for 6 months now. payed a little over 400 for it. very happy
Old May 26, 2012 | 10:03 PM
  #60
sonofmooner's Avatar
I've been running a Yank 3000 with a bolt on tune from Frost. Have about 15k no issue's. I'm Running the cooler that came with my Performabuilt Trans. Sorry don't recall what size it was.
