Make an LS1 an LS6?
Old Jun 7, 2012 | 02:56 AM
777Shock777's Avatar
Default Make an LS1 an LS6?
Hey guys,
I've been researching on buying an LS6, but just thought would it be possible to order the individual parts that would make it an LS6?
Sorry if its such a noob question I don't know too much about internals......... Since I already have an LS1 thats going to be taken apart soon. figured it'd be worth a shot
Old Jun 7, 2012 | 03:24 AM
lemons12's Avatar
Waste of money for what you could have...
ls6 cam
ls6 intake
ls6 heads
Those are the main differences.
Old Jun 7, 2012 | 03:32 AM
ls6 cam
ls6 intake
ls6 heads
I guess I'm asking mainly because I don't know really much at all when it comes to internals...
I'm looking for something that is still streetable, any suggestions?
Old Jun 7, 2012 | 03:36 AM
lemons12's Avatar
Look into something like a 228R from TSP or smaller.. That would give you great driving manners with even a mail order tune and still make awesome power for a 100% street car.
a low-high 22X/22X duration cam with under .600 lift is what you are looking into.
Couple that with the required springs/push rods/timing chain/oil pump and you will love the gains... Add an ls6 intake and a set of heads and you are getting to business.
Old Jun 7, 2012 | 03:37 AM
lemons12's Avatar
Also.. You are an automatic?
You will HAVE to figure in the price of a torque converter and a trans cooler, it is not an option... You have to have one before you install a cam.
Old Jun 7, 2012 | 03:43 AM
I'll have to research into them, are you aware of a good combo off of say TSP or WS6store?
Yeah I'm trying to learn more about torque converters and find one that is good for the street as well...
Old Jun 7, 2012 | 03:49 AM
lemons12's Avatar
I like PTC for the converter... Look into a 3400-3600. Plenty streetable with all the benefits.
http://texas-speed.com/p-1157-texas-...ve-spring.aspx
224R or 228R cam.. I would go with the 228R, everyone always wishes they went bigger. 112 LSA
PAC 1218 springs would be fine
Call and ask which push rod length you would need
That is your cam/springs/push rods.. You will still need to buy an ls2 timing chain and an ls6 oil pump, both are on TSPs web site just look around.
Kyle at thompson motorsports has some nice packages as well for a killer price.
Old Jun 7, 2012 | 04:33 AM
Right on, I was able to find that LS6 oil pump and that cam package.
I am seeing the LS2 timing chain, would it be good to just get a timing set or would the chain be sufficient? I really appreciate it Lemons
Old Jun 7, 2012 | 04:49 AM
lemons12's Avatar
Just the chain will be fine.
Not a problem.
Old Jun 7, 2012 | 05:37 AM
crainholio's Avatar
Here are two articles that spell out the differences between the LS1 and LS6, great reading:
LS6 versus LS1:
http://www.cadillacfaq.com/faq/answe...s6-article.pdf
LS6 version 2 upgrades for 2002:
http://www.cadillacfaq.com/faq/answe...-article-2.pdf
Old Jun 7, 2012 | 08:14 AM
mark21742's Avatar
Since you have an automatic look at atound a 3,600 stall (get a good one like a Yank or Vig) that won't come apart and send their converter clutch through out the tranny and trash it.
You can go to your local auto parts store and pick up a tranny cooler in the rv/ towing section for about $50.
A 228 is a pretty good all around cam if your really not sure what you want and it will give you good gains all over the entire rpm range of the motor.
Ported ls6 oil pump and ls2 chain
Also you will need a tune and look for a deal on an ls6 intake.
If you have more money to spend get dome milled off of your heads and a good valve job or pick up a set of ported 243 or 5.3 heads.
Font forget you will need head bolts and gaskets
Old Jun 7, 2012 | 08:39 AM
98blueSScamaro's Avatar
the blocks are way diff as well
Old Jun 7, 2012 | 08:46 AM
badazz81z28's Avatar
LS6 is only an engine RPO code.
The engine blocks are the same in the later years. It depends on what year you have.
Other than that, the only difference is the cylinder heads (243 vs 241s) and camshaft.
Again depending on the year, the LS1 got the same intake as the LS6.
If you were going to transform an LS1 to an LS6 I would go a different cam as well.
Old Jun 7, 2012 | 09:16 AM
autogeek23's Avatar
yeah the blocks are different. the GM LS page has some info on the ls6 and how its better than the ls1.
Old Jun 7, 2012 | 11:27 AM
PREDATOR-Z's Avatar
The LS6 blocks are internally a different design. The 01/02 intake is similar to the LS6 but slightly different.
So to recap: Technically, no you cannot make a LS6 out of a LS1. What can be done is run LS6 heads and cam on a LS1 but it will still be a LS1.
Old Jun 7, 2012 | 12:46 PM
bmf5150's Avatar
I agree with lemon!
Old Jun 7, 2012 | 01:25 PM
Not a problem.
I tried sending you a PM, but your inbox is full
LS6 versus LS1:
Thats some great info! I'll definitely read into that.
Yeah I'd like a beastier cam that is also street mannered so if I wanna cruise around in it. I am currently looking into heads as well..
haha always good to recap
Old Jun 7, 2012 | 02:07 PM
shows how smart you are. the blocks in the later years are LS6 block's run the number and you will see. and yes they are very different. buy a LS6 long block well worth the money better parts all the way around.
Old Jun 7, 2012 | 02:12 PM
lemons12's Avatar
Cleared inbox...
Old Jun 7, 2012 | 02:13 PM
lemons12's Avatar
Some 15-20% of the later year fbodys received Ls6 blocks, which are identical to the C5Z ls6 blocks.
In this instance, the only thing different would be the cam/heads/valve train/accessories since they were also equipped with the ls6 intake.
