Gain of 50HP by changing rods. . . .
Chris
How much are his LS1 rods?
That is awesome gain. What was the total power output of that Pro Stock motor(NHRA or IHRA?)?
Chris
100 gms is a lot especially if the original rods were already about the lightest 1300 hp/10000 rpm rods out there. A PS engine probably accelerates at 3000+ rpm/second in the lower gears, so lower inertia would be helpful.
The ony PS engine builders I ever met in person wouldn't consider letting folks watch a dyno session or discuss power. Shoot, you can't even see their intake manifolds at the track for all the camo on them. So which team do you work for? And after they read you post you probably won't.
DTS is getting into lots of high end shops, both drag and roundy-round.
Chris
Rods come with A-1 bolts, used by the Fuel teams. . .this is the type parts Jager uses.
Chris
FWIW. I ordered this book today. F1 Racing had an add for it and some pics from the book.... F2000 - 4 valves I believe. Here's the link : Ferrari Formula 1 F2000
From one of Amazon's Customer Reviews:
"My favorite section is on the engine. Here the drawings and explanations are unbelievable. How it all works, individual components laid out, even dyno charts. Same for the other sections like transmission, suspension and aerodynamics. How Ferrari operates as a team is also presented and laid down as perhaps its biggest edge."
joel
Chris
In the attempt to build HP for competition, racers are looking for an edge, that edge puts them out front. This info is cutting edge and I believe some of your subscribers have cars that might want that "edge". The rod is available for any engine combination as the tooling allows.
Some PS engines are 500 CID, Some are 800. Some see 6500 RPM, some pass right on buy it staging.
Hey, going fast is expensive. We had 2 pans go out a few months ago for $18K for the pair, the price you pay to be first.. . .and to sit on the pole.
Chris
and on the relevance issue, if these rods actually did make that much more power, why the hell would someone on here want them? they gotta be so damn light you have to change them every 10th pass....i doubt theres anyone here willing to pull the motor that often to change rods/bearings...
