What to expect out of this setup!!
Old Jul 2, 2012 | 05:01 PM
Z28_LS-WON(1)'s Avatar
Default What to expect out of this setup!!
Im getting ready to start building my engine and wanted to know everyones thoughts, opinion, and any suggestions. I want to know what to expect out of this setup.CompCam 220/230 duration .564/.572lift with a 144+4 lsa, 799 Heads, LS6 intake, stock lid, LT's/ORY. Its through a stock A4 tranny. Ive done a bit of research on similar setups and they put out about 450hp through a M6. Im hoping to get 400RWHP through this setup. I was planning on doing stage 1 porting on the heads.
Please everyone give your thoughts and opinions!
Old Jul 2, 2012 | 06:36 PM
Way2Fast's Avatar
Sounds like a decent setup, not too sure it will make 400 rwhp without a little more port work and a good tune. The a4 sucks up quite a bit of HP. Just put a good convert or in it, some sticky tires and worry about what it does at the strip. Dynos are for tuning. My. 02
Man reread this and thought it sounded harsh. The 98 in my sign only dynoed 373 rwhp and ran those numbers at 3450# race weight. Needless to say it had to put down more power than that to run that number, so that's why I say dynos are for tuning.
Old Jul 2, 2012 | 07:49 PM
How much port work do you think? and I will be getting a stall just not any time soon. This is going to be my daily driver and strip car till i can get a hold of a gas sipper haha.
Old Jul 2, 2012 | 07:51 PM
Sladester2's Avatar
Why stock lid?
Old Jul 2, 2012 | 08:12 PM
Well i was going to get an aftermarket lid till my brother told me i could have his because he was going to get a clear lid. lol no point of buying one if im he going to give it to me for free.
Old Jul 2, 2012 | 08:14 PM
agenthol302's Avatar
thats a very mild set up. if you were to get 400 out of it i would be very suprised
Old Jul 2, 2012 | 08:19 PM
1nasty86's Avatar
Turd Gen Guy
Id say 370-380 unlocked converter... Everything looks good except the fact ur gonna kill the 60e pretty fast... Grab a 3200-3400 converter, tranny cooler and pray
Old Jul 2, 2012 | 08:20 PM
What would for sure make 400 to the wheels? a better cam?
Old Jul 2, 2012 | 08:24 PM
1nasty86's Avatar
Turd Gen Guy
I made 407/382 to the tire with a ls2, 230/238 cam, fast 102, stage 3 ported 317's and a circle d 4000 converter.... for you send your 799 heads to get ported by a sponsor and get a bigger cam and a fast intake
Old Jul 2, 2012 | 08:27 PM
How much would you say this is going to cost?
Old Jul 2, 2012 | 08:29 PM
Way2Fast's Avatar
As far as porting, I would say get the best your budget can afford. Think overall what you want out of the car and look at other setups of cars that are performing the way you want yours to. And I mean this in the nicest ways, don't use the dyno as your only judge.
For example, I am on a budget(like everyone) so I will be getting either Patriots or PRC ls6 heads and then I will choose a cam based on the heads and what I want to achieve. I will start out keeping the ls6 intake, but probably will do a fast intake when money will allow it. I just swung a deal on some TSP 1-7/8" headers and will get their off road y to go with(currently have slp headers). I have a stall, don't know exactly which one as it was in the car when I bought it. Once you put a cam in an A4 car, you will want a stall to maximize the gain, even a 2800-3200 will feel a lot better. I can say I want to see over 400 rwhp, but it doesn't ealy matter to me as long as it performs the way I want it to. My old car ran those times in 2001, so much has changed since then. I drove that car from VA to C and got 24 MPG then. No dyno tune or anything with ported 853s and a B1 can. Needless to say I expect better performance from the new setup and better drive ability.
Old Jul 2, 2012 | 08:43 PM
01'SSLSX's Avatar
^^agreed
i have ported/milled 243's, 233/239 cam, fast 92mm intake and an awsome tune and running through a m6. it made 425hp on a mustang dyno
im running 4.10 gear & 28" tall DR too
Old Jul 2, 2012 | 08:46 PM
I see what your saying and you explained it to a 19 year old newbie damn well. And i just want it to perform good like you said as well. It would be also nice to prove that its a true 400RWHP to others that wont believe me. but i guess thats what the track is for
Old Jul 2, 2012 | 10:51 PM
Sladester2's Avatar
You should check out a tsp 228r cam
Old Jul 2, 2012 | 11:34 PM
Detoxx03's Avatar
I would up the specs on the cam to something in the 228/230 range. With the setup you posted I think you could get 375rwhp out of it with the converter locked.
Old Jul 2, 2012 | 11:38 PM
SStressin's Avatar
i would say anywhere from 360-385 depending on dyno
Old Jul 3, 2012 | 10:14 AM
Way2Fast's Avatar
The other guys are right about the cam. I am thinking around 228-232 for the intake duration myself. You don't want to wish you had gone a little bigger later on.
