EDIT: FINALY GOT IT! (stripped my fuc****crank threads all the way) installing pulley
#61
Alright guys I got it drilled out. Time to make the new threads. I went and talked to a well known machinest in town and he recomended I only used one of the helicoils so that is what I will do. He also recomended with the helicoil to torque to 200ft lbs instead of 250.
#65
I went ahead and changed it out already yesturday. That took 5 mins maybe. Than I got on my helioil **** it and went to pull it on with the PULLEy install TOOL and stripped the threads in the helicoil LMAO. Than I had to take the helioil out (wich is not at all easy) and now I just went and barrowed a tap and di for the m16x2 threads on the pulley install tool and I'm going to redue my helicoil and try all over again here in a little bit. Problem with this install tool is that it won't go far enuf in. I even had to cut it and still doesn't go in deep enuf to ketch on the helicoil threads all the way in. Tonight I'm going to cut it for the last time and make sure it threads in all the way to the helicoil and see if I can't finish this ******* project once and for all. If the helicoil attempt fails again I will have to just tap for a bigger bolt.
#67
you are actually supposed to use the tool to put the seal in, and the cover has to be loose anyways to align it properly with the pulley
there is also a front cover alignment tool that you are supposed to use....
use all the right tools the first time, and you wont have to do it a second time
#69
You can't strip the threads if you are using the proper tool. If anything it will pull the helicoil out which if installed right in nearly impossible. What pulley install tool are you using?????
#70
Read above it stripped this time because pulley tool is not long enuf. It is saposed to be the "proper tool", but I have less threads with the helicoil and this puller is not long enuf. So I am having to cut it to make it work. Unless I am using it wrong wich I don't see how I could be. It is the install tool from autozone
It lookse exactly like this one in the pic below... The threaded peice you see on the bottom hits the crank and won't let the bolt go through it all the way into the threads so I am going to have to cut the threaded peice so I am not pusshing against myself on the crank like last time.
![](http://ecx.images-amazon.com/images/I/51zXm9rfR4L._SL500_SS500_.jpg)
#71
Kleeborp the Moderator™
If the install tool you are using isn't catching all the threads, then it isn't the right tool.
You need a tool like a guy on here was selling...I don't know if he still makes them or not. Hell, I have one sitting in my tool box that clearly won't be seeing the crank of an LS1 anytime soon.
#72
It would work but the helicoil does not have the same amount of threads that used to be there so you have to go further in to get to the threads. I'm going to try cutting it so it will thread all the way in and if it doesn't work I'll have to find a new tool. I'm not risking it not going all the way in again. Whatever the f**** is used will thread all the way or it won't be used. Before I even try to putt the pulley on this time I'm going to use my propane torch and make the bitch glow and hopefully it will slide on and I won't have to worry about pulling it on as much.
#73
#74
It worked for those who could get part of there balancer on. It apears it won't work if you just barely get it on. here is a thread where a bunch used it and it worked fine and than those who couldn't get the pulley on enuf it would not work, but if you just cut the threads on the tool I don't see what would make it any different from any other tool (as long as it threads in all the way). 618hawk please post of a pic of you install tool and than I think I would like to go ahead and buy it. Can you do overnight shipping on it if I pay that?
https://ls1tech.com/forums/tools-fab...utozone-2.html
#79
Drill and tap the crank. Do not trust a helicoil in this application. There is an unbelievable amount of force, that is trying to pull a balancer off the crank, at high rpms. Helicoils have there place, but not on a balancer bolt. You probably won't be able to torque the fastener to its required value, because of the helicoil. Drill and tap it. It's easy. I've done it, because I had to. I tried this method of using a crank bolt to pull on a balancer, over 20 years ago. I didn't know any better. Take the advice of those here: Use the correct tools.
There have been a few threads talking about this very subject. People argue that using a crank bolt Is acceptable. Ok. Until this happens. Now what?
#80
( if it glows its way much hotter than 200°F )
