Do I need to change parts....
Old 09-13-2012, 06:59 AM
Drokkers's Avatar
Arrow Do I need to change parts....
Im want to get the TSP 228 (112lsa) cam for my camaro. I currently have a baby cam (see sig) and when it was first put in the pushrods were changed to chromemoly 7.4s, the retainers were changed to comps steel valve retainers, the valve springs were changed to 918 comp beehives. These parts have roughly 15K miles on them.
My question is, when i go to change the cam, do i have to change these three things? Do i have to change anything else beside these things? Thanks for all the help guys.
Old 09-13-2012, 07:06 AM
supersick99z's Avatar
Pushrods should be measured as always but I don't see why the rest wouldn't be fine
Old 09-13-2012, 07:43 AM
Tainted's Avatar
With 15k miles on the springs already I would just change them out. Its peace of mind knowing a spring isnt gonna break and drop a valve.
Old 09-13-2012, 09:59 AM
Drokkers's Avatar
thanks for the input guys. anyone else, feel free to put your .02 into it
Old 09-13-2012, 10:47 AM
arock24's Avatar
Personally, I'd sell the beehives and go with dual springs. May not be COMPLETELY necessary, but as above poster said, its a peace of mind, and once you go with duals, you won't have to worry if you eve go any larger with your cam.
Old 09-13-2012, 11:12 AM
Drokkers's Avatar
would i need any new gaskets for this as well?
Old 09-13-2012, 01:02 PM
JustAFooL's Avatar
Replace any gaskets that you pull off during the swap. I would anyways
Old 09-13-2012, 01:19 PM
Drokkers's Avatar
oh youre just a fool, what would you know just joking thanks for the reply
Old 09-13-2012, 03:22 PM
Drokkers's Avatar
so technically i could go just a cam and new gaskets and call it a day? i may get new springs, they were gently used since being brand new.
Old 09-13-2012, 04:56 PM
JustAFooL's Avatar
Pretty much, definitely check push rod length though. I'm in the process of doing that now too..
Old 09-14-2012, 06:44 AM
Drokkers's Avatar
what cam are you going with?
Old 09-14-2012, 08:16 AM
Sprayed1998's Avatar
Springs are cheap change then
Old 09-14-2012, 08:32 AM
Drokkers's Avatar
YES SIR!!! kidding, yeah when i do this i will be changing them out. Peace of mind is priceless
Old 09-14-2012, 08:44 AM
J Glen's Avatar
I agree with this. Duals are the way to go.
Old 09-14-2012, 08:52 AM
Drokkers's Avatar
yeah i was able to take a peak at ticks performance springs (brian tooley) on my phone at work(shhhh dont tell) and i will go that route more than likely.
about how much can a tune run ya (i know this can vary)
Old 09-14-2012, 08:55 AM
Tainted's Avatar
A decent dyno tune you can expect $400 +/-
Old 09-14-2012, 09:00 AM
Drokkers's Avatar
cool, i will be doing the install myself, the car isnt a DD so downtime isnt an issue. Right now i can only afford parts. Tune will be a nice christmas gift though.
thanks for the reply tainted
Old 09-14-2012, 09:28 AM
arock24's Avatar
Don't forget a trunion upgrade kit. Tsp has them for $140 I believe and it's a good upgrade for your rockers...another thing for peace of mind..after that you should be set.
Old 09-14-2012, 09:49 AM
Drokkers's Avatar
^ youre killing me smalls
Old 09-14-2012, 10:03 AM
arock24's Avatar
It cost to play. That SHOULD be the last thing on the list though, and it's still cheaper than buying all new rockers.
Quick Reply: Do I need to change parts....
