Please help. Stripped threads
Old Apr 7, 2004 | 09:00 PM
goinbroke's Avatar
Default Please help. Stripped threads
One of the smaller head bolts, M8 - stripped out the threads in the block. Cannot tighten it down. Anybody know a simple solution for this? Remember this is the small top bolt on the heads. Thanks for any help.
Old Apr 7, 2004 | 09:10 PM
felton316's Avatar
helicoil
Old Apr 7, 2004 | 09:21 PM
goinbroke's Avatar
what is that? Not familiar with that.
Old Apr 7, 2004 | 09:35 PM
JoeyGC5's Avatar
A helicoil is a threaded insert. The original hole is drilled out a little, then tapped to the insert size. Insert is placed in block and now you've got a stronger base for the bolt to go in.
Old Apr 8, 2004 | 07:33 AM
goinbroke's Avatar
Where do i get this?
Old Apr 8, 2004 | 08:40 AM
myss2638's Avatar
Any local auto parts store should stock heli coil kits.
Old Apr 8, 2004 | 09:57 AM
LEATHL_WS6's Avatar
You might have to goto a good hardware store to get the metric size you need.
Old Apr 8, 2004 | 11:28 AM
Scalpel's Avatar
Napa and Carquest stock them.
