Are Comp Lifters Better Than LS7 Lifters?
#62
I had plenty of warning, started with a metallic tap that just eventually got worse with mileage. Also notice tiny bits of the metal from the roller on the magnet of drain plug.
#63
Same thing with noisy lifters - lots of people out there with quiet LS7s. Unfortunately I'm not one of them.
#67
LOL, right now my intake is off along with the valley cover. Haven't pulled the heads yet. Dunno if I want morel link bar or regular. I don't beat on it much and currently have a stock LS6 cam. Might go link-bar for future upgrades, but I might swap in a cam now also. Not having to worry about a twisting lifter is a plus.
#68
None link bar lifters will not twist except in the case of a wrong valvetrain set-up' and this until above 8500rpm...been done for years on LS engines.
Link bar lifters will never ever twist, as with a wrong valve train set-up, but destruction of valve-train components will happen, sooner or later, even quicker if you rev your LS engine above 6500rpm...still happening everyday.
Christian
#69
Let me reformulate it if you don't mind.
Christian
Christian
My rev limiter is set to 6500 and I have never hit it, 5500 is the highest I have gone. Brian tooley springs site has the link bar morels for $499, im sure they can get the non link bar ones. I will be contacting them.
#71
#72
I am going to lower the price of the Morel Racing one's I am selling then!!!
Christian
#73
Crap. I was just told by a well-respected LS guru & member here that I should just use LS7 lifters for my application. Said Comps aren't as good and Morels will be noisier. Now what do I do? If I still have ticking with new LS7's and new cam & heads it's time to hide the razor blades
. Did I just get a couple of "bad" LS7's or what?
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
