Heads/CAM HELP !!!
Old Oct 3, 2012 | 11:42 AM
kissmy99ss's Avatar
Default Heads/CAM HELP !!!
I would have asked in other related threads but didnt want to hi-jack someones thread lol.
I'm looking at getting a heads/cam package. my mod list is this (1999 Camaro SS M6)
Corsa Cat-back
Hooker long tubes
LCA's with reloc. brackets
Bilstein Shocks
Short shifter
Built 10 bolt with moser axels and moser 373's
LID
315 Nitto DR's
I'm a college guy and I drive my care daily, so i need it to stay street friendly however I want to make as much power as I can while still being able to have it as a DD. I have never dyno'ed my car so the power it makes right now I have no clue on. Can you guys shoot me some numbers on what you think my car puts down now? and how much i would be looking at with your suggested heads/cam setup? Also can a $3,000 budget get it done?
My best time at the 1/8 track is a 8.8 @84 with a 2.1 60ft that was without the relocation brackets,headers and bilsteins on.
Old Oct 3, 2012 | 11:52 AM
reeperz28's Avatar
Bolt on ls1's with a 6 speed trans usually make in the area of 335- 350 rwhp. Torque is close to hp . A good mild setup for daily driving and budget friendly ish would be some prc 2.5 heads perferably 5.3 's imo. And the 224 cam or 228 from texas speed. With a stock intake it should be good for 420 rwhp average. Study the dyno section and search different heads cam packages.
Old Oct 3, 2012 | 12:02 PM
kissmy99ss's Avatar
Thanks for your input, How often will I need to change out the springs with a 228 cam ?
Old Oct 3, 2012 | 04:32 PM
kissmy99ss's Avatar
Anyone else have some input for me?
Old Oct 3, 2012 | 08:00 PM
2000PewterT/A's Avatar
I check mine every 20k miles, if they are in spec I put them back in.
Old Oct 3, 2012 | 09:52 PM
kissmy99ss's Avatar
well thats not too bad, I just dont want a setup where I have to change or check them every 5k cause that would be a lot of money considering i drive this thing daily lol
Old Oct 4, 2012 | 11:21 PM
1loudTransAm's Avatar
I Daily Drive my car 10 miles a day. I got a 228R Cam fom Texas Speed, very good cam. with a 3600 Stall and a tune. I also getting 14mpg on the city & 22mpg on the highway. 220R, 224R, 228R Cam and PRC LS6 Stage 1 or 2.5 heads are good for DD
Old Oct 6, 2012 | 12:12 AM
kissmy99ss's Avatar
How much out the door should a head/cam package run me including install?
Old Oct 6, 2012 | 03:53 AM
arock24's Avatar
$3000-3500...possibly a little more depending on how much labor is in your area.
Old Oct 6, 2012 | 09:41 AM
tjwashow's Avatar
600 for cam package from Texas speed includes spring pushrods and cam. Get some heads for 1500 and find a local guy to install for you. Preferably a member from the forum who knows what they are doing.
Old Oct 6, 2012 | 09:54 AM
arock24's Avatar
Don't forget about the oil pump, trunion upgrade, lifters, trays, timing chain, and gaskets which will run you about another $650. If you're on a strict budget, pick up a stock set of 243's on here for $400 and get them freshened up at you local machine shop, all for under a grand. Do it right and go with dual springs from TSP, the kit is $740 which isn't bad. This will put you right at $2100 for parts, not including installation or tune. Like I said, $3500 is a little closer to reality for a decent H/C setup after it's all said and done if you have to pay for labor.
Old Oct 6, 2012 | 12:00 PM
kissmy99ss's Avatar
sounds reasonable. For that price is it possible to just pick up a used d1sc kit and throw it on and gain the same amount of HP ?
Old Oct 6, 2012 | 03:04 PM
99 Black Bird T/A's Avatar
Might change the coolant when you drain it for H & C and flush the radiator if that hasn't been done in a while. It's easy to do a little preventive maintaince while doing H&C. Don't be surprised if a radiator hose or two needs replacing etc. Mine is also a 99 about due for new radiator hoses. I would allow some extra money for things that come up unexpected at least a buffer of $1000.
Does your clutch hold well? Sometimes with a big power upgrade a new clutch isn't too far away. I was lucky my stock clutch held up fine after H&C and is still in the car and doesn't slip.
If your doing a 224 or 228 @.050 cam, I suggest allowing some extra money for tuning. This will make for a much better daily driver experience.
Likewise, if you don't have an LS6 intake, I'd get one for the H&C swap so you can get the most out of the mod's your making.
My H & C set up while very old over ten years so I'm not up on the current prices for H & C. I have a 224 XE-R cam. Typically my springs have needed replacement at about 30,000 miles but I'm pretty easy on the car. If I beat on the car a lot, I would be looking at the springs after 20,000 miles.
Old Oct 6, 2012 | 03:28 PM
MikeWS6's Avatar
TSP 228R is a great cam. 50hp gains with no low end loss and its pretty streetable for mostly everyone.
Old Oct 6, 2012 | 03:59 PM
kissmy99ss's Avatar
I have a new radiator and ALL new hoses less than 10K miles so im good there. My clutch and intake I have plans for already replacing them before the heads cam swap. Only thing I think I'll have to be careful with is my rearend. I have a 10 bolt as beefed up as it can get, but lets face it, it's still just a 10-bolt lol
Old Oct 6, 2012 | 04:17 PM
KingPin1094's Avatar
im gonna do the same thing but im going a little more radical. im gonna do the EPS 236/248 cam with .617/.617 lift with PRC 225cc heads and a FAST 92/92 setup with upgraded injectors and the full bolt ons. Im looking to make 450whp+ and still have it be a DD. And im also hoping (and this is really hopeful with a good tune and a light foot) to get 18-25 mpg. i know this really doesnt pertain to you but i figured id through my 2 cents in.
Old Oct 7, 2012 | 12:02 AM
kissmy99ss's Avatar
Hopefully you have a good rear-end, cause with that setup your gonna need one. If you drive it softly no you wont, but as soon as you get that thing on a track and if you get it to hook said goodbye to that 10 bolt. lol not to mention your clutch will need upgrading, if you havn't done that already...
