Cam swap/ Stumped please help/update/got her running
bad plugs?? can some cause backfire?
bad plug cause backfire??
Ok just finished up my head cam build and the plugs I have in my cylinder head got wet from a soil didn't realize it until plugs were in the water can this cause you plugs to faul like almost all of them?? I put 3 plugs in cylinder 2 4 and 6 seemed like it wanted to run but died after 2 question
Can this cause your car to not run longer then 2 seconds
Can the water faul the plug
Thanks
Thanks
Thanks
Thanks
If you want help, try proof reading your posts. Can't understand half the **** you are trying to say.
As far as your ongoing issue....test for spark on every single then check to see if you are getting fuel and if fuel pressure is right on....
I'm getting fuel I'm changing plugs in the am the fuel I had in the car was sitting for 6 months I'm not sure if this is the problem but I tripled checked timing made sure it was on compression stoke lined dot to dot and getting back fire it runs about 3 seconds backfire the cut off
#33
Check spark on each cylinder one by one....disconnect the fuel pump fuse and just crank it over and see if you have spark....the issue you are having sounds like when I had bad coils on one of my previous cars...
#38
Ok got her running I think it was bad gas plus plugs the gas I pulled out was yellow like pee new gas was clear I still have bad gas in there it runs fine at 900 rpm its still on stock tune idle is 500 it dies out and backfire when I let off gas I'm going to open my tb hole some I def need a tune
