Spun Bearing possibly?
I was coming home from work tonight car was running great. I get to a stop light everything still good. I accelerate a little hard but not much when it goes green and about 5 seconds later I loose all power, motor still running but I give it gas and I get nothing. I hear no rattle or anything I downshift to try and figure out what's going on RPM's raise up like normal. Oil pressure shows around 40psi but I still have no power. I coast to a stop and pull off on the side of the road. I notice a bit of grey smoke when I turn the car off. I wait about 10 seconds and fire it back up. No knock or anything but I very very carefully drive it the 1 mile home. I have the same tick I have had for the last year or so from a lifter but no knocking or anything. Idle and Oil pressure stay steady at idle and when I slightly rev it the PSI goes up as it should.
I am a bit paranoid right now because that scared the crap out of me just dying out like that but motor still running. I took it out for a very very short drive after letting it cool off a little bit and it seemed to drive fine. I always figured that a knock usually means bottom end and a tick is normally something in the top end, so should I be worried that I don't hear a knock or what?
Oil pressure is steady and doesn't bounce around but like I said there is a lot of valvetrain noise. I will keep a close eye on the oil pressure to see if it does anything weird, I just wish I had an idea what happened.
I will agree something valvetrain related could cause a noise that would trigger the KS system to pull timing.
But if the grey smoke was something abnormal then I would be worried about something bigger happened and maybe it is burning some coolant or oil. I would do a lot of diagnosis before driving again. I would consider pulling plugs and cranking it to see if any coolant comes out. I would also let it sit for at least overnight and drain the oil watching to see what comes out of the hole first, maybe even catch it in a cup for closer inspection than the rest that hits the drain pan.
"grey smoke" is a little vague though and is something our mind can make us question once we know something is going on and are looking for clues.
Hopefully you get lucky and a sensor died or something triggering a limp mode would expect a CEL from that.
Regarding the oil...drain it into a clean container. I use a white, plastic garbage bag within the container. After draining, let the oil sit...then drain most of the oil from that container, into another clean (garbage bag)container. Examine the remnants of oil from the first container. If there is any sediment/bearing material, you'll see it in the sunshine. If there is no contaminant in the oil, you'll be able to reuse it.
Also, like Old Geezer said, cut the oil filter open. Use a pair of pliers to tear the metal covering open.
I appreciate all the reply's, I noticed this morning when I started it up that oil pressure was around 50psi which is a bit higher than normal for me. I am going to drain the oil this weekend and see what's up. I know my valvetrain is in desperate need of maintenance. Just don't have the time and money like I used to unfortunately.
Tranny shift's smooth as can be, gotta get the POS hydraulics replaced but other than that she shift's just fine. I am starting to lean towards a knock sensor getting tripped I had that issue a couple years ago, but it sure as hell didn't just dog out on the side of the road like that.
I've been workin like hell trying to figure out what happened and haven't been able to find anything yet. It is a 6 speed car I converted it years ago from an A4. Tranny shift's fine in all gears although slipping clutch is possible as it is a few years old. Nearest I can figure is it was either knock sensor got tripped or something got screwed up glitch wise in the ECM. I've been tracking down an electrical issue inside the car for over a year but it's just to accessories not anything engine wise. Only thing i've seen so far is that somehow my dipstick tube is no longer sitting all the way down inside the oilpan so it can be causing some oil to splash out and most likely land on the back side of the flywheel.
