New cams from Tick Performance
Old Aug 9, 2013 | 09:44 AM
  #601
97camaro383's Avatar
Originally Posted by StormTrooperZ06
Hey guys got the car dyno tuned and here's the dyno sheet:
Oh btw gonna put the dyno vid later on today or tomorrow.
Congrats! It put down some solid results.
Old Aug 9, 2013 | 12:03 PM
  #602
Shiftslow's Avatar
Hey Martin, hopefully you can help me out here I just got my parts installed on my car prc 5.3 heads and your sns stage 2 cam sounds great! But...my tuner is having problems tuning the car to get it to idle. Its a 6 speed car and when I throw it in neutral and come to a stop the ilde drops down to about 400 rpm bounces back up to 900 then back down and dies. We cracked the throttle plate open a little bit more and reset the tps it seemed to help for a little bit but its doing the same thing again. Can you offer me or him any words of advice?
Old Aug 9, 2013 | 01:26 PM
  #603
maxpower_454's Avatar
That's the most difficult part of the tune to get right.
Old Aug 9, 2013 | 01:42 PM
  #604
MMWS6's Avatar
http://www.hptuners.com/forum/showth...78-Idle-tuning
Little dated now, but may have something that will make your tuner go "Ah ha!"
  #605
Jimbo1367's Avatar
The "perfect tune" LOL>
Old Aug 9, 2013 | 01:44 PM
  #606
greenvortec97's Avatar
Old Aug 9, 2013 | 01:46 PM
  #607
tell him to look at his Underspeed/overspeed and throttle cracker tables
tell him to run the idle config as well
Old Aug 9, 2013 | 08:15 PM
  #608
Dickie-311's Avatar
Originally Posted by ironmanLS1
Here is what I have so far:
2002 LS1 Camaro
Engine
5.7L
SLP Lid
Throttle body – stock (Potz ported throttle body just installed but not at the track with it)
Stock MAF
LS6 intake
799 heads, decked .012”, stock except with Brian Tooley springs to match the cam
Stock Rockers
Cam - Tick Performance Street Heat Stage 2, 231/238, .610/.580, LSA113+3, 1800-6400 rpm range
Hooker 1-3/4 headers
TSP y-pipe, cats gutted
Catback – stock (Magnaflow catback just added but not to the track with it)
A4 trans
FTI 4000 converter
Stock rear, 3.23 gear
~26-27” rear tire
Mail order tune
Current Performance
12.23@ 109, 1.68 60’
that car has a lot left in it , my motor is completely stock (334whp) @ 3605lbs I have run a best of 12.29 @110
Old Aug 10, 2013 | 01:52 PM
  #609
StormTrooperZ06's Avatar
Thanks man sure pulls really freaking hard!
Old Aug 10, 2013 | 05:47 PM
  #610
Sales@Tick's Avatar
Originally Posted by squalor
I'm not ready to buy but I read the whole thread and learned a lot, thanks Martin.
What closed and open spring pressures, type and spec springs do you recommend for the torqueMAX Stage 2 ? Regular and mild lobe.
If you were designing a cam with the characteristics of the torqueMAX series but was able to use stock LS6 springs how would it measure ?
150lbs. on the seat, 400-420lbs. open. The BTR Platinum spring kit or the PAC 1521 and a few of the new PAC Hot Rod Series springs would work as well.
Those are some very solid results! I would of liked to of seen the graph on SAE correction as well to compare to the STD numbers, but nonetheless Bravo!
What all is done to your car? I know it's cam only, but what consists of those modifications? What year is it?
It sounds to me like it needs more running air flow. If an engine has too much running air flow it will idle hang and not come down in rpm to an idle. If it has too little it will tend to want to stall out when it comes back to an idle and while idling.
Underspeed/overspeed timing can also affect this as well as can the IAC motor tables. It will take some playing with to get it right. I don't do the tuning at our shop and I don't consider myself a tuner, so try and find someone that does this everyday to guide you to what you may need to do!
I bet it does! That thing hasn't even rolled over on itself yet at 6500rpm!!! If your car is an 02 or newer I'd twist that thing's guts out to 7200rpm and take advantage of all of that power.
Old Aug 11, 2013 | 02:13 PM
  #611
I bet it does! That thing hasn't even rolled over on itself yet at 6500rpm!!! If your car is an 02 or newer I'd twist that thing's guts out to 7200rpm and take advantage of all of that power.[/QUOTE]
7200rpm??? How long are you expecting the sns stage 3 to carry the power? I have mine set at 6800rpm right now and hopefully soon I can get on a dyno and see where power drops off.
Old Aug 11, 2013 | 11:18 PM
  #612
Sales@Tick's Avatar
7200rpm??? How long are you expecting the sns stage 3 to carry the power? I have mine set at 6800rpm right now and hopefully soon I can get on a dyno and see where power drops off.[/QUOTE]
Seeing as how it hasn't even begun to roll over in the slightest bit at 6500rpm I guarantee it holds power to within 10-15rwhp of 455 by 7200rpm. That's a power curve that will scoot a Vette down track to a cam only record if the owner was so inclined to do so...hehehe....
You're selling yourself short at 6800rpm IMO Ross. Try a 7200rpm limiter with a 6800rpm shift point.
Old Aug 12, 2013 | 07:44 PM
  #613
Thank you so much sir! the other mods are:Xs power longtube Orx,Corsa xtreme,calloway intake,fast 36lb injectors, slp underdrive pulley, katech oil pump. And the car is an 01
Hey im down hahaha
Old Aug 13, 2013 | 06:45 AM
  #614
Ronny_02_WS6's Avatar
Hey im down hahaha
Hey Storm Trooper, What heads do you have???, also are those numbers with LS6 intake???
Old Aug 13, 2013 | 09:56 AM
  #615
I have the 243 heads and yep those numbers are with ls6 intake.
Old Aug 13, 2013 | 05:30 PM
  #616
Sales@Tick's Avatar
Beast!!! Are you happy with your purchase Storm Trooper?
Now Ronny and Ross both need to dyno their SNS Stage 3's!!! Slackers!!!!!!!!!
Old Aug 13, 2013 | 07:02 PM
  #617
Oh man I'm so happy! Cant wait to put some afr heads and fast in the future. And you don't even know how pumped with this car hahaha.So big thanks to you my friend. Def doing more business with guys, heck I'm saving to buy the Adjustable Clutch Master Cylinder Kit and clutch from you guys later on.
Old Aug 13, 2013 | 07:47 PM
  #618
Qfly's Avatar
Dammit Martin,
you have me having bad dreams about fly cutting!!!! Although when I am finished, the little 347 turns into a 427 so not all is bad..LOL
I figure me fly cutting pistons will go something like this..
And then it will be like!
Cheers,
Q
Old Aug 14, 2013 | 11:01 AM
  #619
Originally Posted by Qfly
Dammit Martin,
Cheers,
Q
I'm in the same boat!! I'm really thinking about pulling the heads and flycutting so I can put in the stage 3 but I really don't want to do all that work again...
Old Aug 14, 2013 | 01:50 PM
  #620
I know, I'm here stationed in Germany and I haven't gotten a chance, I have the mild version of the SNS Stage 3 but I will see what I can do, It pulls really hard even with a tune repository from a similar cam but I tweaked it a little, I've pushed my car in the German Autobahn about 170mph and still had room for more but it's scary, LOL!!! I'll see if I can put a video one of this days.
