New cams from Tick Performance
You know you wanna!!!!
Getter' done!
I just shot in the dark and went with a 230/239, something close to what the true LS3 guys were doing.
Haven't had a chance to dyno yet. Feels a bit lazy under 3k, but screams pretty good up top. Then again, I stuck it on a 115 because I was going boost later down the road. Perhaps on a tighter lsa, it would be a bit less lazy down low.
I'd love to do something like that, I'm sure those heads would cam very similarly to a cathedral port in terms of the IVC to EVO relationship needed.
but my numbers will be delayed until tuesday or wednesday due to the dyno breaking...
setup for those that asked: 243s, btr springs, ls7 lifters, fast 92/92, arh 1 7/8, underdrive pulley, monster stage 2 and 18lb fly wheel
The boss who's doing the work is having time off till the 22nd, sure got me pissed off.
so excited to get mine finished. you have the same head /cam combo i'm doing! what gasket did you use and did you have to flycut?
This is why I sell so many of these cams because they flat out work on the street. Want to make a big cam only car feel dumb they didn't optimize their set-up?
Buy a SNS Stage 2 cam....
To those that have asked for track results and street results on my cams...here you go. Torque rules.
As we found out the hard way with Z28TTM6 car, the 5.3 heads with smaller than a 63cc chamber when used with a .040" gasket and the SNS Stage 2 really should be measured and fly-cut accordingly if it's needed.
Matt,
When we send your heads out after they come back from Ai, I'll have a hat sent with them.
Silverado
408ci (9.2:1 cr)
AFR 225
200 shot(going turbo soon)
224/231 .595/.595 114
5th Gen Camaro
416ci(LS3)
9.28cr w/Weisco pistons,
Manley rods and DragonSlayer 4" crank
LSA Heads - WCCH P&P w/Patriot dual extreme springs.
SS intake/Inconel exhaust valves
Twin turbo - Garrett 3586's w/1.03 a/r
Stock manifolds with dual 3" exhaust
This cam was sent with the turbo kit:
244/248 .624/.624 115 LSA
The shop installed this one instead:
243/247 .623/.623 115LSA 113ICL
