ls2 timing chain question
Old Jan 9, 2013 | 04:55 PM
blackfbird98's Avatar
Default ls2 timing chain question
hey guys so im gonna be doing a heads and cam swap for my 2000 z28 and have a question, i plan on replacing the stock ls1 chain for the ls2 chain but i see i can either purchase the chain by itself or get the chain and gear combo, do i need to have that gear in order for the ls2 chain to fit on my car or can i just slip in on my stock ls1 timing gear?
Old Jan 9, 2013 | 05:00 PM
arock24's Avatar
Your stock gear should be fine. I replaced mine at 120k and did not replace the gear..haven't had any issues. Some people will tell you to switch them both for peace if mind, but it's not necessary.
Old Jan 9, 2013 | 05:15 PM
LeanPocket's Avatar
the chain and sprocket would be great piece of mind, however the chain is adequate
Old Jan 9, 2013 | 05:16 PM
LeanPocket's Avatar
ive never seen the sprocket break, only the chain
Old Jan 10, 2013 | 01:11 AM
5w20's Avatar
Bingo!
Old Jan 12, 2013 | 06:10 AM
RezinTexas's Avatar
my timing gear had noticeable wear at 145k miles, so I replaced the set.
Old Jan 12, 2013 | 01:17 PM
chrisfrost's Avatar
The only reason I know of to replace the gears are 1. You're existing gears have some wear or 2. You are going to run a 4th gen camshaft in which case You need the cam gear so the cam sensor which is located in the timing cover on 4th gens .
Old Jan 12, 2013 | 01:28 PM
GMtechmatt's Avatar
you should be fine with the chain
Old Jan 12, 2013 | 09:21 PM
desertLS1's Avatar
Yup, just the chain here
