Finally pulling the trigger on parts!
Doesn't mean a 454 wouldn't happen eventually. But I don't have $7k to drop on a shortblock.
I've really wanted to put a Ls3 block with a .005" hone and stock crank just
cuz I like the sound of a 377 incher but if I'm gonna buy a new GM block
then darn it I may as well get the LS7 and hone it to 4.130 for a 388 incher
Big Bore/Short Stroke.....just as soon as I stumble across 10 grand...
Having it on the engine stand made it a 15 min job this morning.
Pics:
Now, my question is (and I'm going to ask this since I used a shitty tool before, rednecked it, and damanged my crankshaft) is how do I get the crankshaft timing gear off without further damaging my crank? I know Kent Moore sells tools for this, but I really don't want to pay for Kent Moore tools just to remove this damn thing. What have some of you done to remove this? I need to get this off so I can install the Rollmaster timing gear on the crank.
I still had mine that I had rented from Autozone. Well, I broke two, and it was the most frustrating thing in the world. You just couldn't get the arms "in" enough to get a good grip. I even made a thread bitching about it like a whiny school girl.
The 3 jaw puller from Advance literally made it a 3 minute job. It's a STOUT piece, with enough room to get the jaws in without bottoming out on each other, if that makes sense.
Btw, looks like I might pay 50 for the balancer install tool since it'll double to install the gear as well. I'll buy a tool if I can get at least two uses out of it... Lol
When pulling the crank gear off I normally thread the crank bolt back in the crank and use a puller with a flat nose on the end of it instead of the tapered end.
FWIW I wouldn't worry about running that crank. Clean it up with a roloc disc and call it good. I wouldn't think that little bit of galling on the snout is going to cause any sort of balance issue. Unless you are just wanting an excuse to go bigger.
I did order the Hawks install tool. I probably could have made one, but blah. I know this will work.
Also, I saw the OTC 6667 is probably as good as the Kent Moore pulley removal tool:
I just oiled up the threads to make it super easy.
Now, I'll work on the fuel pump while I wait for the Hawk installer tool to reinstall the Rollmaster timing sprocket.
So, I'm continuing on with my original build plan of flycutting the pistons and putting this thing back together. I just got the Hawks Tool on Sat to install my timing chain crank gear and balancer, so now I can go ahead and get the cam installed and degreed.
I also decided to go ahead and get the ARP rod bolts and a new oil pan gasket. I figure why not. I know the argument for resizing the rods, but I'm going to go with it. I'd rather have a rod bearing go bad than the rod come apart and take out my heads or block...
That crank damage is ugly, but if you clean it up the sharp edges with a dremel, I don't see it really causing a problem long term.
I installed the new EPS cam after cleaning it up with some B-12 chemtool. I coated it in Joe Gibbs assembly lube. I then coated the retainer plate in assembly lube and installed it. It's a new LS3 cam retainer plate and countersunk T40 bolts. They are to be torqued to 11-ft/lbs. My 3/8" torque wrench goes down to 13. So I just went with that.
Next up in the Rollmaster Double Roller timing set. The little guide "nipple" from the camshaft wouldn't fit. So I had to take a 1/4" drill bit and massage the hole for it to sit right on the cam. Because of that, I forgot to check end play. It's impossible to check with the chain on there. And it's a total bitch to install this thing with the double roller. I may end up taking it off to check since the Torrington bearing stuck to the retainer plate when I was trying to get the thing lined up to install. I think it went back on flush or else it wouldn't have torqued down right. I installed Blue loctite on ARP cam bolts and torqued them down to 28ft-lbs.
Next up I started my degree process. I found TDC by checking .050" of travel on my Dial indicator CCW before TDC and CW after TDC. I added the two and divided by 2 and came out with TDC and repositioned my pointer there and zero'd out the timing wheel.
Then, I moved from the piston to the cam. I took an old GM lifter and placed it on the intake lobe and put a 5" extension on my dial indicator on the body of the lifter. I then rotated the crank CCW until I hit maximum lift and went another .050" and recorded the number and went back CW until I went .050" past maximum lift. I ended up with an ICL of 110 when my cam is ground on a 108. Part of it may be that the timing marks were ever so slightly off on the Rollmaster, and I should have played with it some more. Either way, I'm going to remeasure and see if I had an error. If it checks out and I can't reinstall the timing set any closer, I may just advance it 2 degrees and recheck.
