Finally pulling the trigger on parts!
Old Mar 22, 2014 | 10:51 PM
  #941
LilJayV10's Avatar
Originally Posted by JakeFusion
One problem I have... I keep buying ****. I have some more stuff on the way.
And I'm working like 80 hour weeks. So, I don't actually have any time right now to do anything. LOL
Well that's the reason you can keep buying ****.
Old Mar 23, 2014 | 05:19 AM
  #942
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
You could've bought a Vette by now...
Old Mar 23, 2014 | 10:27 AM
  #943
427zm's Avatar
I hear you there! It's been tough to get break in miles over the past 4 weeks w/ all the traveling I've been doing! Work keeps getting in the way of fun!
Yep! that or a LS3/7 stroker
Old Mar 23, 2014 | 10:41 AM
  #944
JakeFusion's Avatar
Super Hulk Smash
Nah. I pour money into the other things that would also need to go into a Vette, so I'm not comig out ahead.
If anything, I'd be spending 3X on the Vette... I'd have 15" Brembos all the way around with $8k forged HREs. And $5k Motons... etc.
And I wouldn't be any faster.
Although, I am looking at my next car already.
I have my eye on a 68 Camaro with a 622 Solid Roller Big Block in it... So that means I'd turn the Trans Am into my daily driver (and gear it more for handling than all out drag racing) and drag race the Camaro...
Old Mar 23, 2014 | 10:47 AM
  #945
427zm's Avatar
You'd be faster, just not at the strip. You'd walk your TA from a roll, and be able to corner. You'd weight some 400lbs less. Love your thoughts though, coilovers, HRE's..., I scratch the Brembos though, and go willywood or AP Racing. More variety of pads to use that are a fraction of the price of brembo pads. Brembo locks you in to their pads only.
Old Mar 23, 2014 | 10:53 AM
  #946
JakeFusion's Avatar
Super Hulk Smash
You assume I won't gut the TA to get it to 3000lbs
Old Mar 23, 2014 | 11:10 AM
  #947
dr_whigham's Avatar
The Scammer Hammer
Old Mar 23, 2014 | 12:17 PM
  #948
ckpitt55's Avatar
lol I love that gif
Old Mar 23, 2014 | 05:30 PM
  #949
A.R. Shale Targa's Avatar
That 68 is Bad *** for sure but isn't your whip almost done and only a 200
shot away from high 9 second potential ???? Get er' done....
Old Apr 18, 2014 | 09:43 PM
  #950
JakeFusion's Avatar
Super Hulk Smash
200 shot should equal high 9s in this thing.
But I FINALLY got a chance to work on it some more. Got the rearend installed with all new stuff. I'm still debating the Viking coilovers or Koni shocks/BMR spring package. I figure the shocks and springs are easy enough to swap out. And once the rearend grenades, I'll just do this all over again.
Pics of the BMR PHB Relo kit (for the Kooks TDs which you can see somewhat in the pics), Founders 3-piece Poly Joint LCAs (I don't think I installed the poly joints right, have a question to Founders), the Founders adjustable PHB, and Founders LCA relo brackets. Nice stuff all around and went together without too much issues (sans the poly joints). I couldn't find the torque specs on the LCAs, PHB, or the PHB body mounts. So, I just did 75ft-lbs for everything, 65ft-lbs for the shocks and upper PHB mount to the body, 16ft-lbs for the swaybar end links. I jacked up the rear until the body moved off the jack stands to load the suspension and final torqued everything. Seems like that's adequate given everything has nylon lock nuts.
Old Apr 18, 2014 | 09:48 PM
  #951
Rise of the Phoenix's Avatar
Good to see an update from you Jake. I would roll with the Vikings, but that's just me.
Old Apr 18, 2014 | 11:10 PM
  #952
JakeFusion's Avatar
Super Hulk Smash
Yeah, I'm torn. Sort of on the fence with how much of a strip car vs a well-rounded car I want...
Old Apr 19, 2014 | 06:20 AM
  #953
dr_whigham's Avatar
The Scammer Hammer
I'd go with UMI's new Viking coilover front & rear...
Old Apr 19, 2014 | 12:18 PM
  #954
JakeFusion's Avatar
Super Hulk Smash
I know. Those look nice. As does the MWC kit.
Old Apr 19, 2014 | 03:55 PM
  #955
427zm's Avatar
Having kids, I'd make it more well rounded. You'll be able to have more fun in it. No kids, blow it out drag car.
Old May 7, 2014 | 11:34 AM
  #956
maxpower_454's Avatar
Any numbers yet?? You've been teasing us for 15 months!! Haha.
Old May 7, 2014 | 12:10 PM
  #957
JakeFusion's Avatar
Super Hulk Smash
House flooded... gotta deal with that **** first. :\
Old May 8, 2014 | 04:13 PM
  #958
JakeFusion's Avatar
Super Hulk Smash
So while waiting for a few contractors to come out... I decided to get the FLT Level 6 trans and CircleD 2E installed with the BMR trans crossmember/TA relo kit.
I still need to get the shifter linkage installed, all the sensors, and the cooling lines run. And of course filled with fluid. But it's in there and ready to go!
Old May 8, 2014 | 04:42 PM
  #959
99Bluz28's Avatar
I'd keep in mind that if you're picky about how well your shocks control your springs, then stick with shocks like Koni, Bilstein, KW, Ridetech. I've tried going with QA1 SA shocks and DA shocks front and rear and I could never get the shock dialed-in for the best control, so I'm not a fan of most drag racing shocks since they never make for a good street or handling shock.
Old May 8, 2014 | 04:47 PM
  #960
JakeFusion's Avatar
Super Hulk Smash
Good to know, Blu.
I'm down to Koni/BMR package or the Viking coilovers. Those vikings just look so good, and the price is right.
Btw, I got a Harbor Freight trans jack and it was awesome to use. Trans slid right into place in about 30 mins.
Also, I checked the depth on the converter, and I was at 1-1/16" of an inch, so I think that's right based on the numbers I've seen of 1.125" with variance of +/- .050" in the depth. It clicked three times. I didn't have my digital meter to check, it did the backstroke in the flood. But using a straight edge and a ruler, that's as close as I got. And I was around .150" of clearance converter to flexplate. So, I think it's good...
