98 trans am ls1 loud knock
couple days ago it started a loud knock
when first started cold its barely noticeable whether idle or driving
once warm its noticeable at idle and driving
if i take off from a red light it knocks loud,then it kinda fades away for about 20 seconds and starts again like it fades when the automatic transmission shifting higher gear.then when im cruising at a set spednits constant and its loud.
freeway driving say im doing steady 60 its knocking,so i speed up to 75 and it doesnt knock at all / steady 75 its knocking loud / accelerating from 75 to 90 once again i cant hear any knock / steady pace at 90 its knocking loud again
i checked my oil when i heard the knock and it barely registered on the dipstick had to add 3 quarts
i dnt think its piston slap becuz it doesnt stop when engine gets warm,when its warm it gets worse
the knock is coming from what sounds like the passenger side valve cover or under the intake manifold area
there is no loss of power
dropping the oil pan would be the first thing to do correct?
My first step would be pull the oil filter and cut it open.
See if you have any bearing material in it.
It will a shiny metallic substance.
Good luck.
the bearing material if this substance were to be there what would it be from bearings?
im sure everyone here loves there ls1's,this is my 1st,i had a 95 trans am lt1 that got totalled.i paid 9,000 cash fot the ls1 every penny i had,wasnt expecting this to happen after only having the car bout 5 years,i dnt have much money but without this car i will be out of a job,place to live,and i would have to put school off.
i really hope whatever it is i can get it fixed for around 700
thanks
the only thing that went bad was the water pump since ive had it.the car up until a few days ago engine was perfect no signs at all of anything closely to going bad.
Even with the loud knock there is no loss in power.
i dont understand how this happened so fast
[IMG]
[/IMG][IMG]
[/IMG] Last edited by gsxrjunkie750; Feb 17, 2013 at 04:33 AM.
The rod knock can just happen out of the blue just like it did , metal fails at some point and unfortunately its always when you need it to NOT happen...
Have you confirmed that it is a rod knock?
[IMG]
[/IMG][IMG]
[/IMG]The rod knock can just happen out of the blue just like it did , metal fails at some point and unfortunately its always when you need it to NOT happen...
how exectly or yet what are the steps in finding out exactly the problem?
thanks.
btw how can something loose in the exhaustsystemor a bad cat make a loud knock?
can anyone tell me what the car is worth as is?
