Milling 5.3 heads to 59cc?
Old Feb 17, 2013 | 02:08 PM
T/ALT1's Avatar
Default Milling 5.3 heads to 59cc?
I am putting together a 2000 ls1 and installing a TSP 233/239 cam along with ported 5.3 heads. I'd like to get these down to 59cc for more compression so I was thinking I would have to mill them .030 to get them down to where I wanted but figured somebody here would have more experience. This is a street/strip setup that will be more strip. I will also check ptv clearance and Flycut the pistons if needed. Thanks
Old Feb 17, 2013 | 02:11 PM
batboy's Avatar
You don't need to mill that much to go from 61cc to 59cc. It's approximately .006" per cc for milling LS heads.
Old Feb 17, 2013 | 02:28 PM
T/ALT1's Avatar
I thought they were 62cc's stock? So I would only need to mill .012 thousandths to get a set of 862's down to 59cc?
Old Feb 17, 2013 | 02:31 PM
Jay Gadsby's Avatar
What are the"rule of thumb" gains as far as compression is concerned? What can one expect from gaining a point if compression in general? I have some 5.3 heads I am going to be using as well and wondered if its worth it to mill. Thanks, not trying to thread jack
Old Feb 17, 2013 | 02:49 PM
T/ALT1's Avatar
It's only like 3% per point of compression which is roughly 10hp per point but it also adds torque and helps when adding larger cams that tend to bleed off cylinder pressure. Since most heads get milled after porting to make sure they are flat and will seal correctly anyways. It normally doesn't cost any extra to mill .005 or .012 so might as well take advantage of free HP and TQ.
Old Feb 17, 2013 | 02:57 PM
Jay Gadsby's Avatar
Nice. Thanks for the info!
Old Feb 17, 2013 | 03:20 PM
batboy's Avatar
According to the SmokeEmUp website, the stock 5.3 heads have 61.15cc combustion chambers. Don't know if your ported ones got massaged any in the chambers or not.
Old Feb 17, 2013 | 03:43 PM
T/ALT1's Avatar
Yeah we'll I didn't get them back yet but I'm sure they will have a little removed. So I'll have them mill .018 off to get them to 59cc or so.
