6.0 heads cam info needed
Old Feb 19, 2013 | 06:12 PM
2002SLPSSCAMARO's Avatar
Default 6.0 heads cam info needed
just picked up a 6.0 lq9 motor with the flat top piston... I have a pair of 241 heads laying around that im gonna p&p and put new valves and springs on, a ls6 intake and a 80 mm tb, wanna trow a decent cam into it without having to cut the valve reliefs into the pistons,,, which cam can i run to make this happen and still get around 500 crank hp?? And is so what is the max the haeds can be milled to incase they need to be milled.... Remember i know that if it doenst need to be milled then i def wont... Too much comp wont be good for 93.. Soo what advice u guys have fore me
Old Feb 19, 2013 | 06:49 PM
redtan's Avatar
Ditch the 241s and start with some 243s instead. Quality valvejob, slight mill for flatness (and 11:1 CR) wiyh a medium cam in the mid 220s and you will easily hit your power goals.
Old Feb 19, 2013 | 06:52 PM
Have 241 laying around and dont wanna pick up any other heads right now... Just wanna use what i have laying around...i know they are better haeds but this is just to get the car back on the street... My race car is getting a 1200+ hp motor soo that where all the money is goin to
Old Feb 20, 2013 | 06:23 AM
PREDATOR-Z's Avatar
Get the 241s ported cnc'd by AI, no mill. Keep stock valves they will be enough for your goals. Then any low 230 duration cam should get you there.
Old Feb 20, 2013 | 06:43 AM
grim_ls1's Avatar
Like predator said, no mill. I'm running an lq9 with stock heads with the comp lsr-273. I got around .08 intake and .1 exhaust clearance. Idk if 241's sit different or not.
Old Feb 20, 2013 | 06:53 AM
Snkebait95's Avatar
If your confident in whoevers porting your heads they will be great. Im using 862 casting heads ported that flow 300cfm, a 238/240 .605/.610 112 (in a 6.0l bored .030 over) and a fast 102. I believe theres a sticky here that claims once ported 241s and 243s have no difference.
Old Feb 20, 2013 | 07:02 AM
grim_ls1's Avatar
243's have smaller combustion chamber than 241's. That's the only difference in ported version. Are you running that cam with stock pistons, no valve reliefs.
Old Feb 20, 2013 | 07:56 AM
Snkebait95's Avatar
Ah yes i forgot. No they have -4cc reliefs, although ive heard youll be fine without reliefs with my cam
Old Feb 20, 2013 | 08:02 AM
grim_ls1's Avatar
That cam is on par with the ms3 cam. I've heard hit and miss stories with the ms3 on stock pistons. Bet you have a nice sounding engine. I can barely hear the rumble of mine.
Old Feb 20, 2013 | 08:26 AM
Snkebait95's Avatar
Still assembing it lol... 2002slpsscamaro, although donkey dick cams have a special place in these engines, if you want a good street/strip car a 233/239 cam would be a good choice. People say youll be a dog down low but who ever races below 2500rpm?
Old Feb 20, 2013 | 04:49 PM
garygnu's Avatar
consider a Texas Speed torquer v2 or v3 cam.
Old Feb 21, 2013 | 06:06 PM
The biggest thing for me in not having to do valve reliefs... Its a pain i dont feel like having to do... Soo anyone have an idea if the 241s with a 0.05 mill and a ms3 or v3 will still have ptv clearance??... No doubt it will make the power but i just worry about the clearance
Old Feb 21, 2013 | 06:57 PM
garygnu's Avatar
the ms3 won't fit if you mill .050 .listen to PRED-Z ,and get a cam spec from AI.
Old Feb 21, 2013 | 07:20 PM
Sorry i ment 0.005... Who is AI??
Old Feb 22, 2013 | 01:23 AM
PREDATOR-Z's Avatar
http://adclick.g.doubleclick.net/acl...dinduction.com
Old Feb 25, 2013 | 07:34 AM
jays78's Avatar
Putting some #s together for a budget build, using the parts I have and buying as little as possible.
Goal is a strong running, smooth idle engine for my 78 corvette, going to use the carb set up, and sticking with my 700r tranny I just got. Its a daily driver.
This is where I am at, haven't pulled the trigger yet, and would like some input from you guys as this is my first ls engine build.
Summit has a .30 over 6.0 block for 675 bucks and I live next door, no shipping.
Set of speed pro pistons .30 over http://www.summitracing.com/parts/su...make/chevrolet
speed pro pistons http://www.summitracing.com/parts/su...make/chevrolet
Parts I have from a 2002 Ls1
Crank
Rods
Heads
Cam
Will the flat top pistons put me around 10.5 compression?
With new bearings this will put me around $1000 to $1100 for a 6.0 long block.
