Lets talk about rocker arms
Thanks
Those are going to be on of my next mods and from what ive seen, they fit under the stock valve covers!
Nate
Nate
Nate
When you set hydraulic lifters right you don't have to adjust them again. I have been building engines for 20 years and there is no way I want non- adjustable rockers on a modified engine.
The Harlands are lighter have less friction and are considerably more stable than the stocks. And when we did a back to back dyno test on the Harlands and stocks we gained 8-10 rwhp. That is enough to help anyone out.
Oh and I never said adjustables were old tech I said guild plates were.
Nate
So if the aftermarket dont flex (same ratio as stock) you will get more lift out of your cam.
Just what I have heard
Factory rocker failure is incredibly uncommon. In general, it is another one of the unrealistic fears placed into people by the internet. I would contribute most stock rocker failures to poor cam design. Some of the lobes people are trying to run with hydraulic lifters are incredibly silly for cars that get driven frequently. When you have to get exotic on your lifters and rockers with a hydraulic lifter daily car, you really need to stop and think about what you're doing.
As for the fit, the 1.7s fit fine on my buddies SS, even with shims. My 1.8s fit fine until I had to shim them. Then the valve covers needed modding.
I went with aftermarket since my car will repeatedly see 6900-7200 rpms for the next two years, and I don't see the stock stamped rocker arms as being as strong. And I think that the stockers will have more deflection.
jimmy
btw, since i swapped them, the engine revs faster
Just curious, but were any of these '01+? And could valvefloat have been a factor?
I agree that a little flex will cost you a little lift but really...how much power are you going to gain from a couple thousandths lift? You can't dyno that. As for frictional losses, look what we're starting with. If there were 10 or even 5 HP worth of friction then you would see tremendous wear in a short amount of time...but yet we normally see virtually NO wear in these valvetrains even after 100K+ miles. Think about the kind of heat that would be caused by the friction required to draw 5 RWHP. Picture the power made by a 5 HP go-cart motor. 5 HP is alot more energy (and heat) than we commonly think of. That's ALOT of heat, thus ALOT of friction, thus ALOT of wear that simply isn't there by any stretch of the imagination.
You can see 1-2 MPH difference two weeks apart in seemingly identical weather with seemingly NO changes to the car. I've seen it with my own cars and other's too many times. That is all too common. You can also see 5-10 RWHP difference in dyno numbers just between the 1st-2nd-and then 3rd pulls on a chassis dyno with NO changes made. Testing has to be done VERY carefully and repeatedly to confirm 5 RWHP gains.
I am convinced that to see measurable power gains by simply swapping rocker arms (keeping the same ratio mind you) that you would have to have some SERIOUS deflection taking place to begin with causing significant lift losses...and that's just not the case or you would see arms structurally failing which I've yet to hear of.
