Should I replace this cam bearing?
Really don't want to replace this thing if I don't have to. Anyone with opinions please reply quick as the cars directly to my left.
Photos make things look worse. Can you feel the scratch? Have you tried smoothing it out with some 2000 grit and oil?
You do need the proper tools and make sure you index the bearings correctly.
I have only had a problem once and it was due to a factory defect in some Durabond cam bearings. Durabond warrantied all 4 boxes of their defective bearings. Now if they would only pay me back my shop time we could call it all good.
If not, I would recommend to smooth it out with some 2000# sandpaper, clean it up good, then run it.
I know this is an old thread but didn't want to start a new one for the same thing.
I have a similar issue, I took the engine apart to clean for a rebuild and in the process of cleaning some of the caustic oven cleaner had washed off the block and sat on the cam bearing for a bit and looks to have dissolved some of the silver Babbitt material to expose the copper underneath. The cam bearings themselves have no score marks and are very smooth, same with the cam that came out, and it only seems to have shown copper on the front bearing.
Is it save to reuse these bearings as I don't have the tool and keep reading about the alignment from factory being more important than replacing if they look ok.
