Help picking which cam to use. LQ4 6.0L in Jeep CJ8
What suggestions might some of you have for a slightly bigger than stock cam in a 4 wheel drive? Comp Cams has the LSR series that look good. Especially the #269LrHR12. Has anybody had any exposure to these? Looking for a cam that will not require tuning the ECM.
Thank you for your input.
Here is what Comp Cams website has:
LSR™ Cathedral Port (Small Displacement or Max Torque, 4.8L-5.3L)
RPM range 1500-6700
Intake duration: 269
Exhaust duration: 277
Duration at .050: Int. 219 Exh. 227
Valve lift: Int. 607 Exh. 614
Lobe lift: Int. 357 Exh. 361
Only mentions 4.8l & 5.3l in the description as well.
RPM range 1500-6700
If you want milder cam lobes and less overlap, then go with a 214(.595" lxl)/218(.598"lxl) 113lsa+4, -10* overlap. I would stick with cams around this size/overlap range. Now if you want a shelf cam then go with a 212/218 within a LSA range of 112-114; there's plenty of them available!
Correct me if I'm wrong, but I thought the LQ4 and LQ9 shared the same cam, with just a different compression ratio (dished vs flat top pistons)?
Any cam mild enough not to require a tune probably isn't worth throwing in, at least for my money.
