4.125" bore with a LQ4 Block?
Old Apr 22, 2004 | 07:08 AM
tommy's Avatar
Default 4.125" bore with a LQ4 Block?
I am thinking of concreting the water jackets of a LQ4 block and boring to 4.125. It is to be the powerplant for my track only drag car. Has anyone tryed this with any luck?
Old Apr 22, 2004 | 07:25 AM
Reckless's Avatar
Super Moderator
I really doubt it. How will you cool it without water jackets?
Old Apr 22, 2004 | 08:10 AM
CHRISPY's Avatar
considering there is only 4.1 bore spacing wouldn't this pose a problem?
Old Apr 22, 2004 | 08:41 AM
DaleMX's Avatar
Well CR5 blocks can be 4.125 and they use the stock LS1 crank I believe, so the bore spacing must be like 4.25
Old Apr 22, 2004 | 09:41 AM
LOnSLO's Avatar
Bore spacing is more like 4.48 I believe. Are you planning on running alcohol?
Old Apr 22, 2004 | 09:47 AM
stealth's Avatar
You can't do 4.125 bore with an LQ4 block, I have one. Maybe 4.080, depending on power levels. Ask MTI.
Old Apr 22, 2004 | 09:52 AM
Taspeed's Avatar
yes if you concrete in the water jackets you could prolly get away with it for a track/drag only car. I have thought about doing this to some 5.3's and expiramenting with it. I was only planning to do a 70% fill. Not a full fill though. I know old school it is common practice to fill the bbc up and run them without water pumps, but again they fire up...make a run and sit for an hour cooling off. so, yes it should be feasible to do. As far as bore size. I'm questioning the thickness of the actual sleeve bore that is there stock. It may not be that thick. You would really need to sonic test it first as that is a LOT of cylinder wall to take away.
Old Apr 22, 2004 | 10:10 AM
DenzSS's Avatar
Yup. There is a lot more cylinder wall than a stock ls1/ls6, but there is no way you can get to a 4.125" bore. With the perfect block, you're looking at more like 4.080" and even then you're getting paper thin on the walls.
We ended up going .030" over on my iron block. It was sonic tested and could have supported more. In a street/strip car, I want a much cylinder wall as I can.
Old Apr 22, 2004 | 10:36 AM
stealth's Avatar
DenzSS,
I want to leave the mountain and make some passes in Topeka, KC, etc. Which track is best?
Old Apr 22, 2004 | 10:47 AM
DenzSS's Avatar
Topeka is the better track, but personally I prefer KCIR. Smaller track, friendlier people, etc. Just a preference.
If you're looking to bust down some good times, I'd hit Topeka first.
Old Apr 22, 2004 | 10:51 AM
stealth's Avatar
OK, I have heard that Topeka is a fast track. Thanks.
Nasty N8's Avatar
We have a 4.125" bore Iron block it is filled with Darton sleeves. It will hold anything you can through at it. The block we have is going to be 1200hp. Should have some dyno runs soon.
Nate
Old Apr 22, 2004 | 10:53 AM
stealth's Avatar
I have not been referring to sleeved blocks.
Old Apr 22, 2004 | 10:54 AM
DenzSS's Avatar
Nor have I.
Old Apr 22, 2004 | 10:59 AM
tommy's Avatar
Did you install the sleeves yourself? Does Darton recommend any epoxies or locking compounds with their sleeves? Thanks for the pictures!
Tommy
Nate
Old Apr 22, 2004 | 11:14 AM
CHRISPY's Avatar
same here, talking about 6L iron blocks bored only. 4.125 isnt going to happen
Old Apr 22, 2004 | 11:24 AM
stealth's Avatar
It's unanimous, you could bore the LQ4 block to as much as 4.080 (I'm at 4.060), or you could sleeve it to a larger bore. The later option is a topic I know little about, but I suspect that it is relatively expensive.
Old Apr 22, 2004 | 11:36 AM
CHRISPY's Avatar
I wouldnt even go .080 (I know people have done it) and I certainly wouldnt' spray a .080 over 6L block.
Even going 0.030 over you should sonic test the block. (thickness can vary a lot between cylinders)
Old Apr 22, 2004 | 11:40 AM
stealth's Avatar
I agree. We have tested my block in every way known to mankind, but I also know a guy here in Denver that tested 6 LQ4 blocks and all of them sucked. If I build another LS1 motor, I'll use aluminum.
DenzSS's Avatar
Yup.
We went .030" so I could spray it if I wanted to. (after sonic testing)
