want a better cam for na .. motor is 9.5.1
ok guy I bought a car from a guy on this forum.. the cam thats is this engine is more for boost and thats just not in my buget right now. so I am looking to get another cam that would give me a nasty idle that with work with the compression i have.. I dont want to change my springs just a cam swamp if any one has this set up or has ideas let me know thanks .. here are my specs
Engine:
Forged 370
LQ9 Engine Block, GM 3.622" Crankshaft (micropolished)
Eagle H-beam 6.125" Connecting Rods /w ARP Rod bolts
Wiseco Forged Pistons, 4.030" Bore -11cc dish
Wiseco Steel top ring - GFX Ring set
ARP Main/Head Studs
Edelbrock Victor Long Headers 1-3/4" --> 1-7/8" Stepped
LS7 Lifters
LS2 Timing Chain
Melling Oil Pump
Comp Camp 215/223 duration, .604/.610 lift, 115 LSA, LSR lobes
comp cam a .625" maximum lift, these Beehive
Chromemoly Pushrods, 7.400"
Beehive Valvesprings
LS3 Intake Manifold
L92 Heads
LS3 Rocker Arm pedestals & LS3 offset intake rocker arms
90MM Throttle Body
85MM MAF
SLP Air Lid
yank 3500 stall
Engine:
Forged 370
ARP Main/Head Studs
LS7 Lifters
LS2 Timing Chain
Melling Oil Pump
LS3 Intake Manifold
L92 Heads
90MM Throttle Body
85MM MAF
SLP Air Lid
yank 3500 stall
Are you going to stay N/A? If so I would do the following:
1) Throw in the proven 230/234 spinmonster grind
2) Mill your l92 heads .030 and put on .040 cometics.
That will give you a huge boost in power.
If you're not gonna mill the heads to boost compression you're gonna want to stick with a much smaller cam than 236/242. That cam will need higher compression to perform. If you run something that size it'll make nice peak numbers but have no ***** or throttle response down low. I am building a 6.0L/L92 heads/LS3 intake with a G5x3 cam (234/242). With the stock lq4 pistons I was afraid it wouldn't perform worth a crap so I milled the heads 0.020"...then got lucky and founs some stock LS2 flat tops to use. Should do pretty well...but with low compression you're gonna want a much smaller cam.
Well I would like to change it for some choppy sound so I guess yes but don't want to to kill the performance that the car has now too bad. I know it sounds bad but this isn't going to be a race car its a clean street car and I know once I can get blower setup it will be a nasty monster . I am just asking if people have lower compression what are some good cams that have a lower lobe seperation that works with low compression
