Prc 225 ms4 cam package
Old Apr 13, 2013 | 10:29 AM
spiderbyk's Avatar
Default Prc 225 ms4 cam package
after studying the boards for a month I decided to pick these prc 225 heads up comboed with ms4 on a 111..fast 102/102 fast 36lb- ftp lid-ls7 lifters trays-trunion kit..tchain..from john at tsp...setup now is pacesetter lts w/orp & magnaflows-tr224-ls6 intake portedtb-slp 85 maf-ud pulley-mti lid-performabuilt lvl2 w/4200 stall-3.73s....what is yalls take with this combo dyno/track #s ...old setup was done august 2002 by thunder racing..I have not been active on these boards for a good while...any opinions would be appreciated.
Old Apr 13, 2013 | 10:42 AM
MYSTIC-1SC's Avatar
Sounds like a solid setup to me!
Old Apr 13, 2013 | 10:58 AM
old93camaro's Avatar
looks good, just remember the fuel pump is almost at its max limit
Old Apr 13, 2013 | 09:11 PM
garygnu's Avatar
mite consider bigger injectors and fuel pump.I would like to see what those heads would do with a custom cam.
Old Apr 15, 2013 | 08:26 AM
spiderbyk's Avatar
oh, its a 99 trans am....i was told to get fast 36 lders (good to 625fwhp) not the 42s...also was told the stock pump was fine...maybe i need to call again..
Old Apr 17, 2013 | 09:48 AM
spiderbyk's Avatar
ne body
Old Apr 17, 2013 | 12:28 PM
Rise of the Phoenix's Avatar
You'll be fine with the bigger injectors and stock fuel pump.
Old Apr 17, 2013 | 03:23 PM
adamantium's Avatar
How much does a package like that with a custom cam go for?
Old Apr 24, 2013 | 11:57 AM
spiderbyk's Avatar
2150...maybe pp will respond better when this setup hits the road..
Old Apr 24, 2013 | 12:29 PM
I wouldn't worry one bit about what other people on here "think" about your setup. It's "your" setup and I'm sure you built it around how "you" drive the car and what "your" goals are. Who really gives a **** about what joe blow says. He's not the one driving the car or spending your hard earned money on the parts. I'm also sure you worked with Texas Speed on the setup, since the parts are theirs, so it sounds like you've got all your bases covered and will make some great power. All that's left to do is get it all installed and enjoy your new monster.
Old Apr 24, 2013 | 01:41 PM
JakeFusion's Avatar
Super Hulk Smash
Who's tuning the car? That'll make a difference in how well it runs since the MS4 is a max type cam.
Also, the FAST 36lbs should be enough - they'll be closer to 43lbs in your rail.
Old Apr 25, 2013 | 10:51 AM
spiderbyk's Avatar
local speed shop here....have not received the h/c package yet...will be a while before i get all this installed....will have tsps 17/8 hders,ory & true duals when i do..to help out the setup
Old May 2, 2013 | 08:58 AM
spiderbyk's Avatar
what spark plug should i run with this setup..
Old May 2, 2013 | 10:15 AM
HCI2000SS's Avatar
NGK TR6's would be a good choice IMO
Old May 2, 2013 | 12:13 PM
R6cowboy's Avatar
on everything except the cam if its a street car. In that case the cam choice could be much better.
Yes for NGK TR6 plugs.
Old May 2, 2013 | 11:58 PM
hart7631's Avatar
I just ordered and recieved my 225 heads and ms4 yesturday. I have a 0 milage ls1, 1 7/8s, fast 102, and a 4000 stall. 410s, 3100 lbs I cant wait to get it all back together. Should be a beast. Please post updates. Itd be great to see what numbers your getting with yours
Old May 3, 2013 | 12:11 AM
JakeFusion's Avatar
Super Hulk Smash
I agree. The LSK lobes in the MS4 are pretty overkill.
Unless your setup is basically like mine. I designed my setup to be able to run an LSK lobe. And then chose endurance lobes so I wouldn't beat all my expensive valvetrain components to ****.
Old May 3, 2013 | 05:19 AM
M1SERY's Avatar
you will be happy with that set up ,ill say if ur tune is spot on , its close to 450hp .
Post numbers after build let us check it out.
Old May 3, 2013 | 08:00 AM
spiderbyk's Avatar
ok..will post #s when installed...it will be 6 wks down the road though...also im hoping to get the tsp headers ory true dual to help.
Old May 3, 2013 | 08:02 AM
R6cowboy's Avatar
Looks like the OP plans on running a LSK lobe with the stock rocker arms, heavy stainless steel valves, LS7 lifters and I'll assume pushrods not very suitable as well. Not a good combo for that MS4 cam what-so-ever. And if TSP suckers/convinces him on getting them PRC .675 EHT dual springs "upgrade", it'll even be worse.
