What's up with Comp Cams ?
I wonder if additional oiling of the lobe would reduce the cam problems discussed here. Aside from the extra lubrication, it'll also reduce (carry away?) some of the heat developed between the roller and the lobe.
I say this because it almost looks like the affected cams have lost their surface heat treatment.
SO, as per newbie NAVYBLUE (welcome to LS1tech!), 1,000 PPM of zinc in the oil and the cats are affected at 50K miles and 800 PPM 100K.
That's not too much of a trade-off to ensure better lubrication.
I'm just hoping to hear more details and testing on the Lucas EOS.
Just ordered my OWN PERSONAL comp cams camshaft Thursday for my motor in my race car. My boss Jonathan's camshaft for his 14:1 434 c.i. nitrous motor showed up Friday as well. It's a solid roller cam and will be spun 8,000rpm on the regular.
I will put my faith in their products until I find a first hand reason not too.
http://www.gf-5.com/uploads/File/SAE_2007-01-1990.pdf
How many ls guys truly degree their cam in, how many check seat pressure on their valve springs at regular intervals? Installing a cam "straight up" is not how you degree a cam but is the standard answer. What always gets me is the guys who want a custom cam with specific valve events yet they don't degree their cam to those custom valve events that they paid extra for. Guys just want to slap **** in and run it 50,000 miles because you can find 10 other guys who have "no problems" with their brand xyz springs yet you won't find any Guys with facts posted on seat pressure of their springs with that amount of miles. Valvetrain instability will kill the best parts out there in a hurry. Hell I even see a lot of guys posting dyno graphs where you can clearly see valve float starting around 6000-6200 rpm and they have no clue there is a problem. It's honestly not their fault because 10 guys on tech said it would be ok.
BTW, Brian Tooley offers a 3/8" that's very reasonably priced if you don't need a custom length. I believe it's $105 for the set.
and I am not just throwing parts together if that was the case i would've been DONE! Its not and im still in the parts acquiring/research stage. But when you start reading so many threads everything starts to blur so thanks for the heads up. There is alot of Good READ in this and many other forums and hope I can eventually get things together. TT
You know as well as I do that there will members that are just pain stricken in fear right now because they "read it on the internet" that their cam is going to fail.
It's just the way it is though. You can lead a horse to water...
