What works with these lifters, So confused
This is my first time removing heads and changing lifters. I have morel solid roller 5452's. Do factory rockers with the trunion kit work with these lifters. I have stock heads with a trex V2 cam. Heads are on and torqued. I got an awesome deal on these lifters thats why I used them. If factory rockers do work how do I find the proper pushrod lentgh? Heard factory rockers will work and heard i need adjustable rockers!!!
Super Hulk Smash
You can run solid lifters on some of the extreme lobes like LSK since they might as well be solid roller anyway. But you need an adjustable rocker to set lash. With solid lifters, you don't set preload. You set valve lash. You get the pushrod to start opening the exhaust valve of the #1 cylinder and then you can adjust the intake valve lash with an adjustable rocker. Set it .020" (measured with a feeler gauge) and then torque it down.
It'd probably work pretty well with a hydraulic camshaft, but the lash is a TOTAL swag since the mechanical/solid roller cams indicate valve lash.
