Pics Of My Advanced Induction Dart/RHS 223cc Heads/Build Thread
#541
Super Hulk Smash
It shouldn't be that tight. Mine pops out no problem.
I put in the bottom hole with the NW. If you have too much slack, that's not good. But if it's too tight, you'll need to open up your cruise control module and adjust the cable length from there. Luckily, I didn't have to do it. So I don't know exactly what's involved.
#542
#552
Got pretty much everything done now. I still need to run the rubber vent tube coming off the passenger side valve cover to either the rubber coupler that connects the TB to the lid, or run it to the lid itself. If I run it to the rubber coupler, I won't need to replace the rubber vent tube, but if I run it to the lid, I'll need a longer line.
I also have not drilled a hole in the lid for the IAC. I'm honestly thinking about zip tying it to somewhere around the engine bay. Would that work? I would think it would be getting air.
#555
Glad to hear you got it all squared away. I know when I was swapping from my 92 to 102 I was ready to burn my car. But after it started and idled great the feeling passed
#557
Let's see if this bump will get Rise of the Phoenix's latest post up here.....
Edit- Yep, it worked!
#559
Gotta do it again.....
Edit- and here we are....
#560
