Head/cam install part suggestions!
Car has:
bolt ons(lts,catback,intake, etc)
3.73s w/ TA rear end cover
Yank ss3600 stall convertor
Strange single adjustables on all 4 corners with 300lbs springs up front
SFC's,panhard,lca,lca relo brackets
Nt05R 315/35/17
Parts that will be going in:
Tsp prc stage 2.5 5.3 heads
Tsp torquer v2 cam
675 dual springs
7.400 pushrods
Ported ls6 oil pump
Ls2 timing chain
Ls7 lifters
Lifter trays
Tsp bolt/gasket kit
What other parts do you guys suggest I should change up or upgrade to while I'm already going to be doing the swap??? Any suggestions/help will be greatly appreciated!! Thanks!
It runs strong for what it is though, and will hang with and/or beat others with higher dyno numbers Trending Topics
Car has:
Nt05R 315/35/17
Tsp torquer v2 cam
675 dual springs
7.400 pushrods
Ported ls6 oil pump
Ls2 timing chain
Ls7 lifters
Lifter trays
Tsp bolt/gasket kit
I ordered tsp 7.400 pushrods and ended up going with 7.350 after I checked, lots of shop rags, I used a razor with a push handle to remove the old gasket off the block. Before careful and inspect all your vacuum hoses for cracks or leaks I had to replace couple of my hoses. Craftsman makes swivel sockets if you dont alreay have I used my tremendously during my heads and cam swap(metric) helped out a lot.
Why such a high spring on a .595 lift cam?
Injectors are a must, fuel pump maybe but probably not. I didn't need one with 460rwhp.
Maybe someone else can chime in on that high spring on a lower lift cam. Not sure if it's a good idea or not. I would think it would cause the valves to work harder than they need to.
