The Dreaded Oil Pump O-Ring
I hope that is all. Don't you think for it to lose the prime like it did, that it almost has to be the o-ring. Either way it has been a frustrsing afternoon!!
20 psi @ idle 30-35 all he way to 6800. i'm pulling the front cover tonight to see if that is the problem.
I ordered two O-rings from Pace, because several Local dealers said they would have to order them also. When I got off work today I went by another dealer and he told me he would have me one in the morning. So I will be tearing the front end down tonight
I think I will try "eallanboggs" method. That should let me get some rtv on the pump and spacer without smearing it everywhere.
Put in new o-ring and some flange sealer on the pump spacers. Cranked it up and the oil pressure immediately went to 60 lbs.
Motto of this story. Never use a used O-ring!
